    VOXL 2 Kits weight
    weight volx2 grams mass
    • E
      Eloi
      Dear,
      Is clear that the computer from VOXL2 is 16 grams.
      But if I want to purchase a full kit like:
      59565367-1eb1-479b-838e-002217e4d020-image.png https://www.modalai.com/products/voxl-2?variant=39914779934771 with the 5G Modem carrier + 5G modem + antennas + GPS option.
      How much weight is it? (without the charger)
      We want to test the drone with the weight to get proper flight times so we can modify it in advance.
      Also, I have some doubts about some weights:
      • Here it says 4 grams: https://docs.modalai.com/voxl-stereo-camera-datasheet/#m0015-1
        Is it just for one camera or both cameras + T cable? How much is the T cable?
      • Here says "Full APM with XT60 connector is 34 grams": https://docs.modalai.com/power-module-v3-datasheet/#size-and-weight
        Which APM are you speaking about? Do you mean with the cables and connectors?
      • When reading about the VOXL 2 Flight deck with 5G LTE, it says it weights 165.3g: https://docs.modalai.com/voxl2-flight-deck-datasheet/
        With what components? GPS? Power Module? Extension cables? With or without the 3D printed case? In that case, how much is the 3D printed case?
      Also no info about IMX412 weight: https://docs.modalai.com/voxl-hires-camera-datasheet/#mdk-m0061-1-m12-imx412-120-fov-buy-here
      and OV7251 weight: https://docs.modalai.com/voxl-tracking-camera-datasheet/#specification
      Eloi
      • E
        Eloi
        Well, no one replied, so I did it myself.
        It weights fully loaded 134.3g (without: 5GHz board + antennas, power cable missing, usb wifi dongle)
        1 Reply Last reply Reply Quote 2
        • E
          Eloi
          Here is the weight in a balance with and without power module.
          For our application, we will change the huge 12AWG cables and XT60 connectors for short 18AWG cables and XT30 connectors.
          Eloi Vilalta
