    Link VIO to stereo instead of tracking camera
    VOXL-CAM
    1026
    • M
      marian
      I'd like your advice on how to connect VIO to the stereo camera instead of the tracking camera. Is it only possible through the extrinsic configuration file or is there a tool that allows you to do it?
      • M
        marian
        I changed the extrinsics.conf to add the reference between imu0 and imu1 to stereo_l, and changed the voxl-qvio-server.conf tu use the stereo camera for qvio instead of tracking camera.
        I have two problems :
        1. when I use the voxl tool to change the extrinsics configuration, it added par default the conf cor imu0 / imu1 to the tracking camera
        2. when I restart the qvio server with the new configuration file it recognise my conf for stereo (I used stereo_l) but it use the tracking intrinsics.yml file instaead of the stero intrinsics conf. And, of course I don't get localisation by stereo camera
        Below is the output of the qvio server:
        voxl-qvio-server
        loading qvio config file
        imu_name: imu1
        cam_name: stereo_l
        odr_hz: 30.000
        use_camera_height_bootstrap: 1
        camera_height_off_ground_m: 0.225
        enable_init_while_moving: 1
        cam_imu_timeshift_s: 0.002
        cam_imu_timeshift_s_uncertainty: 0.001
        T_cam_wrt_imu_uncertainty: 0.005 0.005 0.005
        R_cam_to_imu_uncertainty: 0.040 0.040 0.040
        accl_fsr_ms2: 156.000
        gyro_fsr_rad: 34.000
        accl_noise_std_dev: 0.316
        gyro_noise_std_dev: 0.010
        cam_noise_std_dev: 100.000
        min_std_pixel_noise: 0.500
        fail_high_pixel_noise_points: 1.665
        limited_imu_bw_trigger: 35.000
        gps_imu_time_alignment_s: 0.000
        T_gps_wrt_imu: -0.115 0.450 0.100
        enable_mapping: 1
        enable_gps_vel: 0
        exising instance of qvio-server found, attempting to stop it
        setting scheduler
        set FIFO priority successfully!
        #0:
        parent: imu1
        child: stereo_l
        T_child_wrt_parent: 0.012 0.055 0.008
        RPY_parent_to_child: 0.0 90.0 90.0
        R_child_to_parent: 0.000 -0.000 1.000
        1.000 0.000 -0.000
        -0.000 1.000 0.000
        tbc: 0.012 0.055 0.008
        ombc: 1.209 1.209 1.209 (axis angle)
        ombc: 0.000 90.000 90.000 (RPY deg)
        loading /data/modalai/opencv_tracking_intrinsics.yml
        using camera intrinsics:
        Could you let me know what I am missing there, please?
        • Techsawi TechsawiT
          Techsawi Techsawi
          Hi @marian I'm trying the same solution as my tracking camera is not working, are you able to get it working this way?
          yocto:/etc/modalai$ voxl-qvio-server
          imu_name: imu1
          cam_name: stereo_l
          odr_hz: 30.000
          camera_height_off_ground_m: 0.100
          enable_mapping: 1
          enable_gps_vel: 0
          setting scheduler
          WARNING Failed to set priority, errno = 1
          This seems to be a problem with ADB, the scheduler
          should work properly when this is a background process
          ERROR failed to set scheduler
          #0:
          parent: imu1
          child: stereo_l
          T_child_wrt_parent: 0.017 0.015 0.013
          RPY_parent_to_child: 0.0 0.0 90.0
          R_child_to_parent: 0.000 -1.000 0.000
          1.000 0.000 -0.000
          0.000 0.000 1.000
          tbc: 0.017 0.015 0.013
          ombc: 0.000 0.000 1.571 (axis angle)
          ombc: 0.000 0.000 90.000 (RPY deg)
          focal lengths: 291.001662 291.248381
          principle points: 303.812740 244.632261
          distortion: -0.007658 -0.008713 0.013827 -0.003393
          MachineVision is licensed as community user
          LNX_8074 supported? 1
          LNX_8096 supported? 1
          LNX_IA64 supported? 1
          WINDOWS supported? 0
          AR ERROR: arFileOpen(): Failed to open file: /etc/modalai/vislam/Configuration.SF.xml
          FASTCV: fcvAvailableHardware Linux
          mempool cur block size 307200, new block size 307200
          Please ignore the error about Configuration.SF.xml above. ^^^
          It's an optional file, and should be a warning not an error
          waiting for imu
          waiting for cam
          connected to imu server
          • M
            marian
            No, it doesn't and I did't heard anything from the Modalai's team in this thread 😞
            In fact there are 2 problems:
            1. Extrinsics.conf:
            • when loading a new conf file via voxl tool, if the imu0/traching and imu1/tracking conf is not in the file, the voxl tool will automatically add a default conf of these entries at the and of your conf file
            1. QVIO server:
            • when starting it will load default the opencv_tracking conf as below and can't change it from the conf :
            So, the system seems to be blocked to use only tracking camera for VIO
              Hi All,
              The MVVISLAM library is very touchy and pretty much requires a camera with a wide field of view to give good data. We're aware that the current setup is not very dynamic and are progressing on a couple different solutions:
              Firstly, we've implemented pipelines for a ov9782 sensor with color, 720p, and a field of view that's about halfway between the very-fisheye tracking camera and the current ov7251 pinhole camera. we've primarily been testing the software for this on the VOXL2 platform but the drivers are working on VOXL and we're hoping to have them up for sale in the coming months.
              We've also been updating voxl-qvio-server to be much more dynamic, the dev branch has had a bunch of updates removing some hardcoded places referencing the tracking camera with the intention of supporting the new higher-resolution camera. This code has been proved out on VOXL2 and we currently have a couple platforms flying vio with the new cameras in our lab. We haven't run through extensive testing on voxl1 yet but if you'd like a head start on this the source and build instructions for what we're testing right now is available on the dev branch of the qvio server (though note that this is populated with near daily updates from our team and will often include experimental code).
              • Steve TurnerS
                Steve Turner
                Alex,
                This new work looks great on the dev branch. We might give it a try to see how it performs.
                Highjacking the thread a bit -- have you looked at other VIO algorithms/implementations? Or is QC MVVISLAM about the best you guys have found on the platform, especially given what I imagine is hardware acceleration provided by the library?
                • Andy JaroszA
                  Andy Jarosz
                  I'd also love to see an option for 2 tracking cameras, for an even wider tracking FOV.
                  • M
                    marian @Guest
                    @Alex-Gardner Thank you, is looking good and promising for this use case. I'll give it a try.
