    Get camera Frame from libmodal pipe client
    Modal Pipe Architecture (MPA)
    • Philemon BennerP
      Philemon Benner
      Hey,
      i'm currently working on getting frames from libmodal pipe. I've looked up the examples of modal pipe, also had a look at voxl-streamer but didn't understood too much. Regarding too the struct of the pipe_client_set_camera_helper_cb in modal_pipe_client.h (l.322-355), is there any way to get the actual frame from that? I'm unfortunately not familiar with buffers and how they work. In voxl streamer the context is being used but in the header file only channel, metadata, and the frame beginning pointer? are being mentioned. Is the context the actual frame?
      • Steve TurnerS
        Steve Turner
        Check out https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-streamer/-/blob/master/src/main.c#L87 for an example of how to handle the callback.
        Philemon BennerP 1 Reply Last reply Reply Quote 0
        • Philemon BennerP
          Philemon Benner @Steve Turner
          @Darkhive that's what i've mentioned above in the post. I don't have a clear understanding of how voxl-streamer camera_cb works and i don't want to use gstreamer to get the actual frame.
          • Philemon BennerP
            Philemon Benner
            Would something like that work?
            char* buffer[meta.size_bytes];
            memcpy(buffer, frame, meta.size_bytes);
            • Steve TurnerS
              Steve Turner
              https://gitlab.com/voxl-public/voxl-sdk/services/voxl-portal/-/blob/master/src/video_manager.cpp#L77
              Is an example of allocating a buffer and copying the frame into it. There are some other good examples in that file as well for processing frames and converting them to various formats within the callback. Hope that helps!
