    voxl-tflite-server dev branch build failing
    Modal Pipe Architecture (MPA)
    • Philemon BennerP
      Philemon Benner
      @Matt-Turi
      Hey i've been working on a custom tflite-server version with the tflite-server dev branch. Since yesterday i am suddenly getting a build error when trying to compile in voxl-cross. I think it's an issue with latest voxl-opencv commit(6cf30d47), because it complains about opencv2 not being present. Installation of packages was succesfull via ./install_build_deps.sh.
      Compile Error:
      voxl-cross:~(dev)$ ./build.sh 820
      -- The C compiler identification is GNU 4.9.3
      -- The CXX compiler identification is GNU 4.9.3
      -- Check for working C compiler: /usr/bin/aarch64-linux-gnu-gcc-4.9 - skipped
      -- Check for working CXX compiler: /usr/bin/aarch64-linux-gnu-g++-4.9 - skipped
      -- Configuring done
      -- Generating done
      -- Build files have been written to: /home/root/build64
      [ 75%] Building C object src/CMakeFiles/voxl-tflite-server.dir/resize.c.o
      [ 75%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/inference_helper.cpp.o
      [ 75%] Building CXX object src/CMakeFiles/voxl-tflite-server.dir/main.cpp.o
      In file included from /usr/aarch64-linux-gnu-2.23/include/features.h:367:0,
                       from /usr/aarch64-linux-gnu-2.23/include/stdio.h:27,
                       from /home/root/src/resize.c:1:
      /usr/aarch64-linux-gnu-2.23/include/bits/stdlib.h:64:8: warning: no previous declaration for 'ptsname_r' [-Wmissing-declarations]
       __NTH (ptsname_r (int __fd, char *__buf, size_t __buflen))
      /usr/aarch64-linux-gnu-2.23/include/sys/cdefs.h:57:59: note: in definition of macro '__NTH'
       #  define __NTH(fct) __attribute__ ((__nothrow__ __LEAF)) fct
      In file included from /home/root/src/inference_helper.cpp:34:0:
      /home/root/src/../include/inference_helper.h:7:30: fatal error: opencv2/opencv.hpp: No such file or directory
       #include <opencv2/opencv.hpp>
      compilation terminated.
      In file included from /home/root/src/main.cpp:47:0:
      src/CMakeFiles/voxl-tflite-server.dir/build.make:75: recipe for target 'src/CMakeFiles/voxl-tflite-server.dir/inference_helper.cpp.o' failed
      make[2]: *** [src/CMakeFiles/voxl-tflite-server.dir/inference_helper.cpp.o] Error 1
      make[2]: *** Waiting for unfinished jobs....
      src/CMakeFiles/voxl-tflite-server.dir/build.make:89: recipe for target 'src/CMakeFiles/voxl-tflite-server.dir/main.cpp.o' failed
      make[2]: *** [src/CMakeFiles/voxl-tflite-server.dir/main.cpp.o] Error 1
      CMakeFiles/Makefile2:97: recipe for target 'src/CMakeFiles/voxl-tflite-server.dir/all' failed
      make[1]: *** [src/CMakeFiles/voxl-tflite-server.dir/all] Error 2
      Makefile:135: recipe for target 'all' failed
      make: *** [all] Error 2
      • Philemon BennerP
        Philemon Benner
        Also a nice thing to add is this to build.sh:
        trap 'err=$?; echo >&2 "Exiting on error $err"; exit $err' ERR
        It exits directly after make installation fails.
          @Philemon-Benner thanks for pointing this out, just fixed with commit c75b7b91.
          • Philemon BennerP
            Philemon Benner
            @Matt-Turi Thank you
