running voxl-tflite-server dev
hi,
I have been trying to run the new voxl-tflite-server dev branch but when I ran the
./deploy_to_voxl_sh, I received the error:
Is it possible to solve it?
just in case it matters: I built using
./install_build_deps.sh devand./build.sh 820 -
Hey @Harel-Yadid,
In order to properly install packages from the dev branches/repo, you must point opkg on VOXL to the dev repo as well so the same packages are available. You can do this by running
voxl:/$ voxl-configure-opkg dev -
Thanks for the answer!
it worked great after the upgrades.what I am trying to do now is to run the deeplab dnn, but I am having some issues.
I tried to run the 865 build but i couldn't run any tflite dnn.
then I tried to run the 820 build which worked perfectly and than added manually the deeplab dnn.eventually i received the error:
do you have any suggestions?
