  2. VOXL Dev Kits
  3. VOXL-CAM
  4. Add a Hires cam on VOXL CAM + TOF w/ Flight Controller
5 Posts 2 Posters 1.2k Views 1 Watching
  • M Offline
    M Offline
    marian
    I just get a VOXl Cam with TOF and voxl desk flight, which has a TOF, a stereo and a tracking camera. Can I attached a Hires cam on it, too? I need to take photos and i want to do it through the voxl system if possible
    • ? Offline
      Hi Marian,
      The voxl-cam can support the use of a hires camera, but the voxl board can only support 3 MIPI cameras at a time. So you could add a hires cam but it would be at the expense of either stereo or TOF. You can see the list of supported camera configurations here. However, If you want all 3 of the built ins and a hires cam, you can use an external camera attached via usb to the voxl and access it via voxl-uvc-server. Documentation of this process as well as some tested cameras can be found here.
      • M Offline
        M Offline
        marian
        wrote on last edited by marian
        @Alex-Gardner said in Add a Hires cam on VOXL CAM + TOF w/ Flight Controller:
        found
        Thank you for your answer!
        I will keep the all three already installed on the voxl-cam and I will attach an external c270 firstly to test with it. Which USB port is recommended to use in this case?
        • ? Offline
          It won't matter which port the camera is plugged into, If you don't have an expansion board/modem on your cam then the micro port is the only usb option, though it'll likely be more reliable in flight to use a manually crimped JST connection on an expansion board and avoid a micro connector.
          • M Offline
            M Offline
            marian
            Understood. Thank you again!
