  3. ROS2 foxy not working on the voxl.
voxl-2
6 Posts 3 Posters 564 Views
  • J Offline
    J Offline
    jbiscan21
    After following install instructions, I keep getting this error when running the voxl_mpa_to_ros2_node
    terminate called after throwing an instance of 'std::bad_alloc'
    • A Offline
      ApoorvThapliyal
      Hello, could you describe your setup a bit? What version of voxl-suite are you using? If you could send me the output of voxl-version that would be really helpful
      J 1 Reply Last reply
      • A ApoorvThapliyal
        J Offline
        J Offline
        jbiscan21
        wrote on last edited by jbiscan21
        @ApoorvThapliyal
        I am using 1.6.3. Here is my attached output. Thank you!
        starling2-max (D0012):~$ voxl-version
        kernel:       #1 SMP PREEMPT Wed Oct 22 04:29:38 UTC 2025 4.19.125
        hw platform:  M0054
        mach.var:     1.2.1
        SKU:          MRB-D0012-4-V2-C29-T8-M36-X0
        voxl-suite:   1.6.3
        Packages:
        Repo:  http://voxl-packages.modalai.com/ qrb5165 stable
        Last Updated: 2026-07-22 18:10:26
        List:
        libfc-sensor                   1.0.9
        libmodal-cv                    0.6.0
        libmodal-exposure              0.1.4
        libmodal-flow                  1.0.3
        libmodal-journal               0.2.7
        libmodal-json                  0.4.8
        libmodal-pipe                  2.14.11
        libqrb5165-io                  0.6.3
        libvoxl-cci-direct             0.3.3
        libvoxl-codec                  0.0.2
        libvoxl-cutils                 0.1.6
        modalai-slpi                   1.2.2
        mv-voxl                        0.1-r0
        qrb5165-bind                   0.1-r0
        qrb5165-dfs-server             0.2.0
        qrb5165-mini-tof-server        0.2.2
        qrb5165-rangefinder-server     0.1.6
        qrb5165-slpi-test-sig          01-r0
        qrb5165-tflite                 2.17.2
        voxl-bind-spektrum             0.1.1
        voxl-camera-calibration        0.6.1
        voxl-camera-server             2.2.19
        voxl-ceres-solver              2:2.0.0-2
        voxl-configurator              1.1.5
        voxl-cpu-monitor               0.7.7
        voxl-docker-support            1.3.1
        voxl-elrs                      1.1.0
        voxl-esc                       1.5.7
        voxl-esptool                   0.2.0
        voxl-feature-tracker           0.5.2
        voxl-flow-server               0.3.6
        voxl-gphoto2-server            0.0.10
        voxl-imu-server                2.0.1
        voxl-io-server                 0.0.8
        voxl-jpeg-turbo                2.1.3-7
        voxl-lepton-server             1.3.3
        voxl-lepton-tracker            0.0.4
        voxl-libgeographic             1.0.0
        voxl-libgphoto2                0.0.4
        voxl-libuvc                    1.0.7
        voxl-logger                    0.6.1
        voxl-mapper                    0.2.4
        voxl-mavcam-manager            0.6.0
        voxl-mavlink                   0.1.6
        voxl-mavlink-server            1.4.14
        voxl-microdds-agent            3.0.0-0
        voxl-modem                     1.2.3
        voxl-mongoose                  7.19.0
        voxl-mpa-to-ros                0.3.9
        voxl-mpa-to-ros2               0.0.7
        voxl-mpa-tools                 1.5.6
        voxl-nano-tracker              0.1.7
        voxl-nlopt                     2.5.0-5
        voxl-open-vins-server          0.6.0
        voxl-opencv                    4.5.5-3
        voxl-osd                       0.3.8
        voxl-portal                    0.8.7
        voxl-px4                       1.15.3-2.0.88-202606042017
        voxl-px4-params                0.9.0
        voxl-qvio-server               1.2.3
        voxl-remote-id                 0.0.9
        voxl-reset-slpi                0.0.1
        voxl-ros2-foxy                 0.0.1
        voxl-state-estimator           0.0.6
        voxl-streamer                  0.8.0
        voxl-suite                     1.6.3
        voxl-tag-detector              0.1.0
        voxl-tflite-server             0.5.1
        voxl-utils                     2.0.2
        voxl-uvc-server                0.1.7
        voxl-vision-hub                1.9.21
        voxl-voxblox                   1.1.5
        voxl-vtx                       2.0.2
        voxl-wavemux                   0.0.3
        voxl2-io                       0.0.3
        voxl2-security-hardening-utls  1.0-r0
        voxl2-system-image             1.8.06-r0
        voxl2-wlan                     1.0-r0
        • B Offline
          B Offline
          brahim
          Hello @jbiscan21
          I have not been able to reproduce this.
          What is your camera config? I am guessing the mpa to ros2 node is bridging both camera and IMU?
          • B brahim
            Hello @jbiscan21
            J Offline
            J Offline
            jbiscan21
            @brahim Hm, after a few reboots and trying again a few days later it is working. Do you know where this package lives so I can inspect the source code? I am not sure what the ros2 node is doing but I do see topics relating to imu and camera data.
            I have the Starling2 Max C29 config in regards to sensors.
            ing2-max (D0012):~$ ros2 run voxl_mpa_to_ros2 voxl_mpa_to_ros2_node
            Found new interface: yolo11_tflite_data
            2026-07-28 21:25:30.085 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
            Found new interface: hires_front_large_color
            2026-07-28 21:25:36.819 [SUBSCRIBER Error] Deserialization of data failed -> Function deserialize_change
            Found new interface: hires_front_large_encoded
            Found new interface: hires_front_large_grey
            Found new interface: hires_front_small_color
            Found new interface: hires_front_small_encoded
            Found new interface: hires_front_small_grey
            Found new interface: hires_front_snapshot
            Found new interface: tof_conf
            Found new interface: tof_depth
            Found new interface: tof_ir
            Found new interface: tracking_down
            Found new interface: tracking_down_bayer
            Found new interface: tracking_down_misp_encoded
            Found new interface: tracking_down_misp_grey
            Found new interface: tracking_down_misp_norm
            Found new interface: tracking_front
            Found new interface: tracking_front_bayer
            Found new interface: tracking_front_misp_encoded
            Found new interface: tracking_front_misp_grey
            Found new interface: tracking_front_misp_norm
            Found new interface: imu_apps
            Found new interface: imu_apps_body
            Found new interface: imu_apps_notemp
            Found new interface: imu_apps_raw
            Found new interface: imu_mavlink
            Found new interface: tof_pc
            Found new interface: voa_pc_out
            Found new interface: voxl_mapper_aligned_ptcloud
            Found new interface: vvhub_body_wrt_fixed
            Found new interface: vvhub_body_wrt_local
            Found new interface: ov
            Found new interface: vvhub_aligned_vio
            • B Offline
              B Offline
              brahim
              MPA to ROS2 can be found here: https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-mpa-to-ros2
