    Can't run the voxl-emulator docker image
    VOXL
    • C
      colerose
      I'm trying to run the voxl-emulator docker image to test code intended for the voxl without the voxl.
      I downloaded the voxl-emulator V1.7 file from https://developer.modalai.com/asset and ran
      "docker load < voxl-emulator_V1.7.tgz" to load the image.
      I tried to run it with the following commands but I keep getting the same error. Is anyone able to help me with this? Picture of terminal output is attached below.
        Hi Cole,
        It looks like you need to tag the docker image as latest. Right now docker only lists 1.7 (which is the latest version, but :latest is looking for an actual image with that tag, not just the most recent image. If you run docker tag 55d4f01b7bcd voxl-emulator:latest then the voxl-docker command should work.
        • C
          colerose
          Hi @Alex-Gardner. I ran that command and got the same issue as before. Here is the output:
            Alex Kushleyev ModalAI Team
            It looks like your machine does not have QEMU support or is missing ARM support on your host machine. Please try instructions here : https://www.stereolabs.com/docs/docker/building-arm-container-on-x86/ (which also show you how to run ARM64 docker images on x86)
