    The Spektrum Cannot be binded, and QGroundcontrol “Detected 0 radio channels. To operate PX4 you need at least 5 channels”
    785
    • D
      DarkKnightCH
      Hello,I am using a Spektrum DX6i(the Modulation is DSM2, and there are 6 channels ), After configuring the IP address in the conf file and connecting to the m500 over QGroundControl, the QGroundcontrol says “Detected 0 radio channels. To operate PX4 you need at least 5 channels”. Does anyone know anything about this issue?
      • M
        modaltb ModalAI Team
        Sounds like you have the MAVLink over IP connection working from VOXL to GGC.
        The RC radio is a different 'band', some info here: https://docs.modalai.com/flight-core-radios/
        Basically you'll want to have a joystick transmitter and you 'bind' it (e.g. pair) together and can use it for RC control (manual flying, testing, etc.)
        • D
          DarkKnightCH
          Yes. You are right. There is connection between the VOXL and QGroundControl, Since in my QGroundControl I can see some IMU data of my quadcopter. But I also want to bind the spektrum RC radio transimitter and spektrum receiver, so I follow those step(RC radio setup) in your official website.!
          I tried to click the spektrum Bind and the QGroundControl will say "Detected 0 radio channels. To operate PX4 you need at least 5 channels", so what should I do to bind my spektrum RC radio transimitter and spektrum receiver?
          M 1 Reply Last reply 11 Aug 2021, 14:10 Reply Quote 0
          • M
            modaltb ModalAI Team @DarkKnightCH
            @DarkKnightCH ,
            Can you look at the receiver after pressing the button? Does it begin to flash an orange LED quickly?
            D 1 Reply Last reply 12 Aug 2021, 04:22 Reply Quote 0
            • M
              Also, what transmitter make and model are you using?
              • D
                DarkKnightCH @modaltb
                @modaltb Sorry, I made a mistake. You are right, once I press the 'spektrum bind' button, the orange LED on receiver starts to flash. This actually means my receiver is already in the binding mode. But when I click the 'calibrate' button, the Qgroundcontrol will say “Detected 0 radio channels. To operate PX4 you need at least 5 channels”. The transmitter that I am using is Spektrum DX6i, do I need to setup something in my transmitter?
                M 1 Reply Last reply 12 Aug 2021, 13:27 Reply Quote 0
                • M
                  @DarkKnightCH
                  I normally see this if I don’t reset the PX4 FW after binding. Did you try to power cycle the vehicle?
                  • M
                    Also yes there's a binding procedure to connect the transmitter to the receiver. Normally you have to hold a button down whilst powering on the transmitter until you hear a beep or see the receiver go solid.
                    D 1 Reply Last reply 16 Aug 2021, 14:44 Reply Quote 0
                    • D
                      @modaltb Thank you so much. I followed your instruction and then reboot the quadcopter, then it works. But there is a new issue: When I calibrate the radio, the radio channels for roll, yaw and throttle looks good, but for pitch angle, it shows 'not mapped'. I checked Qgroundcontrol: 'Vehicle Setup->Parameter->Radio Calibration', RC_MAP_ROLL is channel1, the RC_MAP_PITCH is channel2, RC_MAP_THROTTLE is channel3 and RC_MAP_YAW is channel4.
                      Do you know what's wrong about the pitch radio channel mapping?
                      • M
                        Hi @DarkKnightCH ,
                        It's likely something you can setup in your transmitter, or perhaps reset the transmitter to default state. What make and model do you have?
                        1 out of 10
