  3. Invalid local position
30 Posts 5 Posters 10.2k Views 3 Watching
  • ? Offline
    Hi Dillon,
    What services are running? The required ones for flying with VIO are voxl-camera-server, voxl-imu-server, voxl-qvio-server, and voxl-vision-px4. Can you paste the output of voxl-inspect-services here?
    • D Offline
      D Offline
      DillonAllen
      Here are the services that are currently running:
      yocto:/$ voxl-inspect-services
       Service Name        |  Enabled  |   Running   |  CPU Usage
       docker-autorun      | Disabled  | Not Running | Not Running
       docker-daemon       | Disabled  | Not Running | Not Running
       modallink-relink    | Disabled  | Not Running | Not Running
       voxl-camera-server  |  Enabled  | Not Running | Not Running
       voxl-cpu-monitor    |  Enabled  |   Running   |   0.0%
       voxl-dfs-server     |  Enabled  |   Running   |   1.7%
       voxl-imu-server     |  Enabled  |   Running   |   1.3%
       voxl-modem          | Disabled  | Not Running | Not Running
       voxl-qvio-server    |  Enabled  |   Running   |   0.0%
       voxl-streamer       | Disabled  | Not Running | Not Running
       voxl-tag-detector   |  Enabled  | Not Running | Not Running
       voxl-tflite-server  |  Enabled  |   Running   |   0.0%
       voxl-time-sync      | Disabled  | Not Running | Not Running
       voxl-vision-px4     |  Enabled  |   Running   |   1.8%
      • ? Offline
        There's the problem, voxl-camera-server is not running. Since it's enabled (and I'm assuming that you didn't stop it yourself) it probably aborted. This is usually due to a hardware issue with one of the camera cables. Can you now paste the output of journalctl -u voxl-camera-server to see what the logs for camera server say.
        • D Offline
          D Offline
          DillonAllen
          Okay, While I was waiting for your reply I went ahead and checked all of the cables and unplugged and re-plugged all of the cameras on the board and now I am getting this from the services:
           voxl-camera-server  |  Enabled  |   Running   |   7.5%
           voxl-dfs-server     |  Enabled  |   Running   |  10.0%
           voxl-imu-server     |  Enabled  |   Running   |   1.9%
           voxl-qvio-server    |  Enabled  |   Running   |   2.2%
           voxl-tag-detector   |  Enabled  |   Running   |   4.1%
           voxl-vision-px4     |  Enabled  |   Running   |   2.0%
          • ? Offline
            Are you still not getting localization data?
            • D Offline
              D Offline
              DillonAllen
              Still getting invalid local position data
              • D Offline
                D Offline
                DillonAllen
                Heres the output from QGC:
                nsh> ekf2 status
                INFO  [ekf2] local position: invalid
                INFO  [ekf2] global position: invalid
                INFO  [ekf2] time slip: 0 us
                ekf2: update: 8677 events, 49546us elapsed, 5.71us avg, min 1us max 94us 4.090us rms
                nsh> listener vehicle_visual_odometry
                TOPIC: vehicle_visual_odometry
                 vehicle_odometry_s
                    timestamp: 431364179  (297.960915 seconds ago)
                    timestamp_sample: 431346994  (17185 us before timestamp)
                    x: -682.8690
                    y: -951.3774
                    z: -868.9987
                    q: [0.9878, -0.0083, 0.0614, -0.1428]
                    q_offset: [0.0000, 0.0000, 0.0000, 0.0000]
                    pose_covariance: [nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan]
                    vx: 0.0002
                    vy: 0.0009
                    vz: -0.0032
                    rollspeed: 0.0095
                    pitchspeed: 0.0000
                    yawspeed: 0.0000
                    velocity_covariance: [nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan, nan]
                    local_frame: 1
                    velocity_frame: 3
                nsh>
                • ? Offline
                  Do you see data from voxl-inspect-qvio
                  • D Offline
                    D Offline
                    DillonAllen
                    Yes, but it is very iffy, when I have it sitting on my desk and move it around all of the data changes like it should, but then when I move it to the floor or vice versa then it will start giving me the LOW_FEATURES error
                     T_imu_wrt_vio (m)   |Roll Pitch Yaw (deg)| state| error_code
                       -0.02   -0.01   -0.07|   0.2    0.4    0.2| OKAY |
                    • ? Offline
                      Yeah it'll be unstable when its being moved around like that, it's meant to have the service start at the takeoff location and then track initial features on the floor/wall during takeoff. However, this does show that localization data is coming from the VIO service, so the problem is further down the line.
                      The two things to look at now are the vvpx4 config file at cat /etc/modalai/voxl-vision-px4.conf and make sure that the QGC stuff is set up properly, and that en_vio and send_vio_to_qgc are both set to true.
                      If all of that looks good, then you should run voxl-inspect-pose vvpx4_body_wrt_local to see if the voxl-vision-px4 service is getting the localization data peroperly.
                      • D Offline
                        D Offline
                        DillonAllen
                        I believe that I have the voxl-vision-px4 setup correctly for QGC, here is the conf file:
                        yocto:/$ cat /etc/modalai/voxl-vision-px4.conf
                        	"qgc_ip":	"192.168.8.20",
                        	"en_secondary_qgc":	false,
                        	"secondary_qgc_ip":	"192.168.1.214",
                        	"qgc_udp_port_number":	14550,
                        	"udp_mtu":	512,
                        	"en_vio":	true,
                        	"en_voa":	false,
                        	"en_send_vio_to_qgc":	true,
                        	"en_send_voa_to_qgc":	false,
                        	"en_set_clock_from_gps":	true,
                        	"en_force_onboard_mav1_mode":	true,
                        	"en_reset_px4_on_error":	true,
                        	"qvio_auto_reset_quality":	0.00050000002374872565,
                        	"en_adsb":	false,
                        	"adsb_uart_bus":	7,
                        	"adsb_uart_baudrate":	57600,
                        	"px4_uart_bus":	5,
                        	"px4_uart_baudrate":	921600,
                        	"offboard_mode":	"figure_eight",
                        	"follow_tag_id":	0,
                        	"en_tag_fixed_frame":	false,
                        	"fixed_frame_filter_len":	5,
                        	"en_transform_mavlink_pos_setpoints_from_fixed_frame":	false
                        And here is the output for voxl-inspect-pose vvpx4_body_wrt_local:
                        timestamp(ms)|     Position (m)     | Roll Pitch Yaw (deg) |    Velocity (m/s)    | angular rate (deg/s) |
                              153336 |   0.00  -0.01  -0.09 |   -0.6   11.0   -0.2 |  -0.00   0.00   0.00 |  -0.00  -0.03   0.01
                        • ? Offline
                          Yeah that all looks fine, but there's no data in the local_position_ned or either of the odometry messages?
                          • D Offline
                            D Offline
                            DillonAllen
                            In QGC I only have the ODOMETRY data, but there is no local_position_ned tab if that is what you're referring to.
                            • ? Offline
                              And what happens if you try to put it in position mode?
                              • D Offline
                                D Offline
                                DillonAllen
                                It just tells me "REJECT POSITION CONTROL"
                                • ? Offline
                                  I've asked some of our px4 experts what their thoughts are, can you share your px4 params file so we can see what's going on there since this seems to be a px4-side issue.
                                  • D Offline
                                    D Offline
                                    DillonAllen
                                    I couldn't figure out how to share the file through here, so I uploaded them to a drop box:
                                    https://www.dropbox.com/s/7kxknquutoav00i/PX4_Param_Voxl.params?dl=0
                                    • ? Offline
                                      We noticed that your EKF2 Aid mask is different from what we usually run, did you install the voxl px4 parameters file as here or did you create your own? Can you try to run with our default parameters file and see what happens?
                                      • D Offline
                                        D Offline
                                        DillonAllen
                                        I ran the parameters from the quickstart guide, I also ran the indoor_VIO helper and just changed the aid mask to fit was in the quickstart guide. I reverted it back to its original settings and the drone is still having the same problems.
                                        • D Offline
                                          D Offline
                                          DillonAllen
                                          So I've tried completely resetting the parameters on the drone back to factory and reloading all of the parameters again, but I am still getting invalid local position data.
                                          Also as a small side note, should the tracking camera be inverted? (for example, I move an object from the top of the tracking camera and it shows up from the bottom on the feed)
