  3. 4K Hires Camera crashes camera server
21 Posts 3 Posters 5.8k Views 1 Watching
    @riteshsharma,
    Are you using VOXL1 or VOXL2? it seems VOXL1 based on the terminal output.
    Which SDK do you have installed?
    I am going to assume this is VOXL1, it is possible that it does not have enough memory designated for camera pipeline for all the buffers.
    Are you able to change the number of NUM_RECORD_BUFFERS from 16 to 8 or 10? https://gitlab.com/voxl-public/voxl-sdk/services/voxl-camera-server/-/blob/master/src/hal3_camera_mgr.cpp?ref_type=heads#L86
    I believe we increased the number of buffers at some point and the 4K30 use was missed in testing on VOXL1.
    If you are able to experiment with number of buffers yourself, that would be great, maybe the easiest way to do this is to get the camera server repo on your VOXL1 and compile on target with modified number of buffers. If you cannot compile the camera server in any way, i can help you.
    also in your earlier posts, you showed more prints that print out the buffer info, such as:
        Count Min: 16
        Count Actual: 16
    etc
    This is the buffer information for the two cameras, you can see if less than 16 were allocated for the hires camera (camera 0)
    Also, i see you are using three ov7251 cameras, which also require some additional "special" memory and perhaps we missed testing that use case with 16 buffers, so reducing number of recording buffers should solve the issue (it looks like it is able to allocate 11 of them, but you can use 8 to be safe)
    R 1 Reply Last reply
          Count Min: 16
          Count Actual: 16
      etc
      R Offline
      R Offline
      riteshsharma
      @Alex-Kushleyev Hi Alex, Thank you for your suggestion, I will try to change the buffers to 10. I have two stereo camera ("ov7251"), one tracking camera ("ov7251"), one flir boson camera ("uvc") and one Hires camera ("imx412"). I am trying to operate all cameras on VOXL1 together. I am not sure if 10 buffers will be enough.
      • R riteshsharma
        @riteshsharma , the number of buffers is per camera 🙂 so 16 is definitely an overkill
          R Offline
          R Offline
          riteshsharma
          wrote on last edited by riteshsharma
          #14
          @Alex-Kushleyev Hi Alex, I tried changing buffer to 8. It is still failing to initialize encoder for hires camera.
          Starting Camera: tracking (id #1)
          Using gain limits min: 100 max: 6399
          Starting Camera: hires (id #0)
          pthread_setaffinity_np: Success
          WARNING: Port Def 0:
          Count Min: 11
          Count Actual: 11
          Buffers Contiguous: Yes
          Buffer Alignment: 0
          WARNING: Port Def 1:
          Count Min: 16
          Count Actual: 16
          Buffers Contiguous: No
          Buffer Alignment: 0
          WARNING: Encoder expecting(11) more buffers than module allocated(8)
          ERROR: OMX Set config failed!
          ERROR: Failed to initialize encoder for camera: hires
          ERROR: Failed to start camera: hires
          Starting Camera: stereo (id #2)
          with buffers set to 12, it is still failing to start:
          ERROR: Failed to get correct number of buffers from OMX module, expected: 12 got: 11
          ERROR: OMX SetPortParams of PortIndexIn failed!
          ------ voxl-camera-server: Started 2 of 3 cameras
          • R riteshsharma
            Count Min: 11
            Count Actual: 11
            Buffer Alignment: 0
            Count Min: 16
            Count Actual: 16
            Buffer Alignment: 0
            @riteshsharma
            Can you try 11?
              @riteshsharma
              Can you try 11?
              Also, just for the test, you could try to disable the other cameras and see if the system is able to allocate more buffers for hires camera (12?)
              I can test your setup sometime soon and provide better recommendations, I just dont have it in front of me right now.
                R Offline
                R Offline
                riteshsharma
                @Alex-Kushleyev Hi Alex, buffer when set to 11 works. I am able to see all my cameras. But now I am not seeing hires_large_encoded and hires_small_encoded stream on my voxl-portal.
                • R riteshsharma
                  R Offline
                  R Offline
                  riteshsharma
                  #18
                  @Alex-Kushleyev I have one more question about the length of the cable for connecting Hires (imx412) 4k Camera. I tried using more than one extension and it does not work. Do you have any suggestion for longer wire or extension.
                  • R riteshsharma
                    @riteshsharma , good progress.. i dont think voxl-portal is able to display h264 stream.
                    If you use “voxl-inspect-cam -a” , it should show stream stats. Also you can view the h264 stream using voxl-streamer, at least that is what we do on voxl2.
                    Regarding chaining the extension flex cables, our tests also showed that only one extension works for imx412 due to high data rate. Other cameras may be able to go longer. We dont have a longer solution for imx412
                      R Offline
                      R Offline
                      riteshsharma
                      @Alex-Kushleyev Thanks Alex. You have been great help.
                      • R riteshsharma
                        @riteshsharma you are welcome. If the current approach initializes and works fine (is able to allocate all the buffers), the performance should be stable. I am a bit surprised so many buffers are needed for the encoder, there is probably some other settings in our software to change that... However since it is actually working with 11 buffers, maybe there is no need for me to test / fix that. If you do encounter any other issues, let me know..
