    Issues Getting voxl-streamer video stream working through RTSP stream on Doodle Labs Helix Radio
    • John Nomikos 0J
      John Nomikos 0
      Good afternoon,
      Recently, I've been attempting to configure a setup on the VOXL2 that uses a doodle labs helix radio and a gremsy gimbal.
      HDMI from the camera on the gremsy is routed through an HDMI capture card to USB-C on top of the naked 5G expander board. And USB from the doodle is going through USB-2 on the board.
      I have been able to successfully get the camera going on voxl-uvc-server and it is outputting frames. I have also been able to view the stream through Ethernet and it looks smooth. It is running on a 640x480 stream at around 1 mbps.
      However, when using the doodle radio, the stream will cut out immediately to the point where it is unviewable.
      I've tried both decreasing and increasing the bitrate and ran into the same problems. I also tried moving one doodle further away from the other and the stream kept cutting out. However, I can still control the gimbal fine.
      Also, here is the output I was getting from voxl-streamer when the stream kept cutting out and not connecting on ATAK:
      voxl2:/$ voxl-streamer --standalone --port 8903 -i gremsy
      Waiting for pipe gremsy to appear
      Found Pipe
      ERROR: object missing width
      WARNING: Failed to fetch one or more of width, height, into_format, framerate from pipe info file
      WARNING: going to connect to the pipe for 1 frame to inspect it now
      WARNING: grabbed the data from the actual pipe and closed it
      detected following stats from pipe:
      w: 640 h: 480 fps: 0 format: YUV422
      Stream available at rtsp://127.0.0.1:8903/live
      A new client rtsp://10.223.0.150:46914(null) has connected, total clients: 1
      Camera server Connected
      ERROR:   New frame rejected, status = -2
      rtsp client disconnected, total clients: 0
      no more rtsp clients, closing source pipe intentionally
      A new client rtsp://10.223.0.150:46916(null) has connected, total clients: 1
      A new client rtsp://10.223.0.150:46918(null) has connected, total clients: 1
      A new client rtsp://10.223.0.150:46920(null) has connected, total clients: 1
      This "new frame rejected" error would continue on and on, over and over again.
      This is on platform 1.0.0
      voxl-streamer is version 1.7.1
      voxl-uvc-server is version 0.1.3
      I was wondering if there are recommended camera settings I should set on voxl-streamer to work with the doodle radio, or if there is insight on the errors voxl-streamer is running into.
      Thank you,
      John Nomikos.
      wilkinsafW 1 Reply Last reply Reply Quote 0
      • wilkinsafW
        wilkinsaf ModalAI Team @John Nomikos 0
        @John-Nomikos-0
        I bet that we can hook up an hdmi camera camera and try to duplicate this on the bench
        John Nomikos 0J 1 Reply Last reply Reply Quote 0
        • John Nomikos 0J
          John Nomikos 0 @wilkinsaf
          @wilkinsaf I completely agree. We can compare to a normal USB camera as well to see if the issue is with specifically streaming from the HDMI to USB capture card
