<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[Issues Getting voxl-streamer video stream working through RTSP stream on Doodle Labs Helix Radio]]></title><description><![CDATA[<p dir="auto">Good afternoon,</p>
<p dir="auto">Recently, I've been attempting to configure a setup on the VOXL2 that uses a doodle labs helix radio and a gremsy gimbal.</p>
<p dir="auto">HDMI from the camera on the gremsy is routed through an HDMI capture card to USB-C on top of the naked 5G expander board. And USB from the doodle is going through USB-2 on the board.</p>
<p dir="auto">I have been able to successfully get the camera going on voxl-uvc-server and it is outputting frames. I have also been able to view the stream through Ethernet and it looks smooth. It is running on a 640x480 stream at around 1 mbps.</p>
<p dir="auto">However, when using the doodle radio, the stream will cut out immediately to the point where it is unviewable.</p>
<p dir="auto">I've tried both decreasing and increasing the bitrate and ran into the same problems. I also tried moving one doodle further away from the other and the stream kept cutting out. However, I can still control the gimbal fine.</p>
<p dir="auto">Also, here is the output I was getting from voxl-streamer when the stream kept cutting out and not connecting on ATAK:</p>
<pre><code>voxl2:/$ voxl-streamer --standalone --port 8903 -i gremsy
Waiting for pipe gremsy to appear
Found Pipe
ERROR: object missing width
WARNING: Failed to fetch one or more of width, height, into_format, framerate from pipe info file
WARNING: going to connect to the pipe for 1 frame to inspect it now
WARNING: grabbed the data from the actual pipe and closed it
detected following stats from pipe:
w: 640 h: 480 fps: 0 format: YUV422
Stream available at rtsp://127.0.0.1:8903/live
A new client rtsp://10.223.0.150:46914(null) has connected, total clients: 1
Camera server Connected
ERROR:   New frame rejected, status = -2
rtsp client disconnected, total clients: 0
no more rtsp clients, closing source pipe intentionally
A new client rtsp://10.223.0.150:46916(null) has connected, total clients: 1
A new client rtsp://10.223.0.150:46918(null) has connected, total clients: 1
A new client rtsp://10.223.0.150:46920(null) has connected, total clients: 1
<p dir="auto">This "new frame rejected" error would continue on and on, over and over again.</p>
<p dir="auto">This is on platform 1.0.0<br />
voxl-streamer is version 1.7.1<br />
voxl-uvc-server is version 0.1.3</p>
<p dir="auto">I was wondering if there are recommended camera settings I should set on voxl-streamer to work with the doodle radio, or if there is insight on the errors voxl-streamer is running into.</p>
<p dir="auto">Thank you,</p>
<p dir="auto">John Nomikos.</p>
]]></description><link>https://forum.modalai.com/topic/2651/issues-getting-voxl-streamer-video-stream-working-through-rtsp-stream-on-doodle-labs-helix-radio</link><generator>RSS for Node</generator><lastBuildDate>Fri, 13 Mar 2026 14:46:31 GMT</lastBuildDate><atom:link href="https://forum.modalai.com/topic/2651.rss" rel="self" type="application/rss+xml"/><pubDate>Wed, 13 Sep 2023 21:30:46 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to Issues Getting voxl-streamer video stream working through RTSP stream on Doodle Labs Helix Radio on Thu, 02 Nov 2023 21:24:13 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/413">@wilkinsaf</a> I completely agree. We can compare to a normal USB camera as well to see if the issue is with specifically streaming from the HDMI to USB capture card</p>
]]></description><link>https://forum.modalai.com/post/12991</link><guid isPermaLink="true">https://forum.modalai.com/post/12991</guid><dc:creator><![CDATA[John Nomikos 0]]></dc:creator><pubDate>Thu, 02 Nov 2023 21:24:13 GMT</pubDate></item><item><title><![CDATA[Reply to Issues Getting voxl-streamer video stream working through RTSP stream on Doodle Labs Helix Radio on Thu, 02 Nov 2023 21:22:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="https://forum.modalai.com/uid/1678">@John-Nomikos-0</a></p>
<p dir="auto">I bet that we can hook up an hdmi camera camera and try to duplicate this on the bench</p>
]]></description><link>https://forum.modalai.com/post/12990</link><guid isPermaLink="true">https://forum.modalai.com/post/12990</guid><dc:creator><![CDATA[wilkinsaf]]></dc:creator><pubDate>Thu, 02 Nov 2023 21:22:43 GMT</pubDate></item></channel></rss>
