  3. (Platform 1.0.0) Bug in the most recent VOXL2 ESC Firmware (Random motors reverse directions each arm)
voxl-2
35 Posts 4 Posters 10.9k Views 3 Watching
  • John Nomikos 0J John Nomikos 0
    @Alex-Kushleyev Thank you for the advice. Changing that parameter allowed me to set power back down to 80 with no issues.
    Hmm also QGC does show that the actuators are mapped correctly. I also double checked that props are on right and are spinning the right direction. I will investigate further. I'm trying to fly it in VIO currently.
    Is it necessary to calibrate the escs with voxl-esc-calibrate.py? I have not done that.
    @John-Nomikos-0
    Yes, you should perform the ESC calibration - it should be done for best results whenever you have a new motor or propeller type. There is more information about it in the other thread you found. Then you would need to update your PX4 parameters for min and max rpm so the commanded thrust is properly mapped to what motors can achieve.
    Also, if you are experimenting with new motors and props, it is always better to fly in manual mode to make sure the basic flight is working properly and then test higher level modes like VIO.
    @modaltb , are there any other params that need updating if John is using a custom drone for his custom motor/prop combo?
    John Nomikos 0J 1 Reply Last reply
      @John-Nomikos-0
      John Nomikos 0J Offline
      John Nomikos 0
      The interesting thing is that these aren't new motors and props. We got them working previously on the older esc firmware and even did PID tuning. Drone was flying smoothly. But of course, changing the ESC firmware parameters could have completely invalidated that.
        @John-Nomikos-0 , i see. In that case, if you kept the old control parameters the same (such as the calibration curve and gainst, etc), the new firmware should work the same. The new firmware only had changes that relate to the spin-up procedure. Therefore, if you have migrated your old params to the new params correctly (you could double check that all the control params should be the same between your old param file and new param file), then the issue may be somewhere else. You should try to fly in non VIO mode, just manual mode to check if the drone flies well manually.
          John Nomikos 0
          wrote on last edited by John Nomikos 0
          #14
          @Alex-Kushleyev And just to confirm, the actuators tab should be where I am testing that the motors are mapped correctly, right?
          We were seeing this problem when flying in stabilized flight mode as well. I can try manual next
          John Nomikos 0J modaltbM 2 Replies Last reply
            John Nomikos 0
            Even in manual mode it tries to eat dirt as soon as it tries to lift off. I triple checked, motors are mapped correctly and spinning in the right direction
              modaltbM Offline
              modaltbM Offline
              modaltb
              #16
              Hey @John-Nomikos-0 , you'll need to know how things are wired up to "quickly" be able to use this guide: https://docs.modalai.com/modal-esc-px4-user-guide/#actuator-setup-using-qgc
              If you don't know the wiring, it becomes a fun guess and check game....
              To reverse, you could try these I believe:
              MODAL_IO_SDIR1
              MODAL_IO_SDIR2
              MODAL_IO_SDIR3
              MODAL_IO_SDIR4
              • modaltbM modaltb
                MODAL_IO_SDIR1
                MODAL_IO_SDIR2
                MODAL_IO_SDIR3
                MODAL_IO_SDIR4
                John Nomikos 0
                @modaltb I have actually successfully been able to use the "Identify and assign motors" functionality, so I was using that to identify the motors.
                I'm going to try via command line just to make sure that the actuator test matches with what is expected
                  John Nomikos 0
                  #18
                  @John-Nomikos-0
                  Double checked using command line
                  actuator_test set
                  It matches what I see on the actuators tab.
                  Moving back to previous ESC firmware to see if problem persists.
                  Nevermind, I think I would need to plug into ESCs to do that
                    @John-Nomikos-0
                    actuator_test set
                    John Nomikos 0
                    Just to clarify, I am still unable to fly with the most recent ESC firmware. All of the motors are mapped correctly and the props are on right, but the drone still seems to eat dirt whenever I throttle it up. It even completely flipped over once. I tried in manual mode and same story.
                    Any other suggestions? I'm starting to run out of ideas 😢
                    Alex KushleyevA Eric KatzfeyE 2 Replies Last reply
                      @John-Nomikos-0 i have asked for help from our other devs, we will follow up with further suggestions.
                        @John-Nomikos-0 Is this on a custom drone? Seems like perhaps a bad PX4 parameter somewhere. Maybe you can wipe everything and start from scratch?
                          John Nomikos 0
                          #22
                          @Eric-Katzfey Maybe there's something with my ESC firmware parameters that's causing issues?
                          I'm going to try to flash an esc config that is used on a modalai drone to see if it's any different
                          Also, is there an easy way to go to the previous ESC firmware version without manually plugging in? I want to go back to see if this is due to the firmware flash in a time-efficient manner. I'm pretty sure there isn't but I wanted to make absolute sure
                          Also it is on a custom drone, but we got our drone flying with the exact same parameters on the previous ESC version on 1.0.0. Really is seeming like an ESC firmware issue to me.
                            @John-Nomikos-0
                            Yes i can provide you with old firmware for m0117 (the original firmware you had before). You will need your old ESC params. All this can be done right from voxl2 without unplugging. I will follow up tomorrow morning.
                              @John-Nomikos-0
                              John Nomikos 0
                              @Alex-Kushleyev said in (Platform 1.0.0) Bug in the most recent VOXL2 ESC Firmware (Random motors reverse directions each arm):
                              Sounds good. I don't think we ever changed the ESC params on the old firmware version. So they would be whatever the ESC came out of the factory with. I'm assuming there are default parameters available for the old firmware, right?
                                @John-Nomikos-0 , yes i will provide the default params that are loaded during production.
                                  #26
                                  @John-Nomikos-0 ,
                                  I have uploaded the older firmware that was used during production of M0117-1 ESC : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/dev/voxl-esc-tools/firmware/old/modalai_esc_firmware_m0117_1_v0_36_f75f1fdb.bin
                                  The default params that are loaded with that are here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/blob/params-v1/voxl-esc-params/old/esc_params_modalai_4_in_1_revb.xml (please note that this is not the same as the latest esc_params_modalai_4_in_1_revb.xml in dev or master branch.
                                  (you can put the old firmware file into the following location: /usr/share/modalai/voxl-esc-tools/firmware/
                                  Note that if you want to perform the ESC downgrade right on VOXL 2, you need to get both of these files on your VOXL2 and run the following commands:
                                  #disable PX4
                                  voxl-esc enable-bridge
                                  #upload firmware to each ESC ID (you will hear a sad beep after each update, which means the params are invalid - this is ok
                                  python3 voxl-esc-upload-firmware.py --firmware-file firmware/modalai_esc_firmware_m0117_1_v0_36_f75f1fdb.bin --id 0
                                  python3 voxl-esc-upload-firmware.py --firmware-file firmware/modalai_esc_firmware_m0117_1_v0_36_f75f1fdb.bin --id 1
                                  python3 voxl-esc-upload-firmware.py --firmware-file firmware/modalai_esc_firmware_m0117_1_v0_36_f75f1fdb.bin --id 2
                                  python3 voxl-esc-upload-firmware.py --firmware-file firmware/modalai_esc_firmware_m0117_1_v0_36_f75f1fdb.bin --id 3
                                  #upload old params (one command to update params on all 4 ESCs)
                                  python3 voxl-esc-upload-params.py --params-file <path_to_your_params_file>/esc_params_modalai_4_in_1_revb.xml
                                  #detect the ESCs
                                  python3 voxl-esc-scan.py
                                  #re-enable PX4
                                  voxl-esc disable-bridge
                                  Your firmware has should now be updated to have the hash f75f1fdb, which is the original firmware that you had on the ESC and the old firmware esc_params_modalai_4_in_1_revb.xml should have been the firmware that you received installed during production.
                                  Depending on the baud rate that you use in your latest ESC params, you may have to update it (the old baud rate was 250K but it could have been changed to 2Mbit, please double check).
                                  Let me know if you have any issues in this process
                                  John Nomikos 0J 2 Replies Last reply
                                    @John-Nomikos-0 ,
                                    #disable PX4
                                    #detect the ESCs
                                    #re-enable PX4
                                    John Nomikos 0
                                    #27
                                    @Alex-Kushleyev Thank you so much for the help. I will try this next week. Have a great weekend!
                                      @John-Nomikos-0 ,
                                      #disable PX4
                                      #detect the ESCs
                                      #re-enable PX4
                                      John Nomikos 0
                                      So I successfully flashed the firmware on all 4 ESCs. But uploading params gave me this error
                                      voxl2:/usr/share/modalai/voxl-esc-tools$ python3 voxl-esc-upload-params.py --params-file /esc_params_modalai_4_in_1_revb.xml
                                      [GCC 8.4.0]
                                      INFO: Params file name : /esc_params_modalai_4_in_1_revb.xml
                                      INFO: Params file size : 6971 bytes
                                      VOXL Platform: M0054
                                      Detected VOXL2 M0054 or M0104!
                                      Found previous connection information in .voxl_esc_cache ..
                                      Prioritizing /dev/slpi-uart-2 @ 2000000
                                      Sending library name request: libslpi_uart_bridge_slpi.so
                                      INFO: Scanning for ESC firmware: /dev/slpi-uart-2, baud: 230400
                                      INFO: ESC(s) detected on port: /dev/slpi-uart-2, baud rate: 57600
                                      INFO: ESCs detected:
                                      INFO: ---------------------
                                      ID: 0, SW: 36, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      ID: 1, SW: 36, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      ID: 2, SW: 36, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      ID: 3, SW: 36, HW: 34: ModalAi 4-in-1 ESC (M0117-1)
                                      ERROR: ESC firmware version 36 is incompatible with params supported by this utility
                                             Acceptable ESC firmware versions are:  [38]
                                      I think voxl-esc-upload-params is checking for the version. I could modify it and try again, unless there is an earlier tool meant for this firmware
                                        [GCC 8.4.0]
                                        @John-Nomikos-0 ,
                                        Yes, you are right, in order to load older params, you need earlier version of the voxl-esc tools. Please use this version of voxl-esc tools, you can check it out right onto your VOXL2 next to the latest voxl-esc tools (do not overwrite) : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl-esc/-/tree/params-v1
                                        Everything else should work the same with old tools.
                                        Sorry about that, i forgot to mention it 🙂
                                          @John-Nomikos-0 ,
                                          John Nomikos 0
                                          @Alex-Kushleyev Thank you. Successfully uploaded params
