Issue in Microhard paring with Slave unit
@manzur
pDDLis the default Network ID. Which Microhard modules are you using? 1800 MHz? 2400 MHz? It looks as though the VOXL side is fully functional.Are you able to take the standalone side Mircohard module and plug it into a PC in order to see if it correctly connects to the PC? That way you would be able to try pinging it to determine whether the IP address is being set correctly.
@manzur From what I can see, it looks as though the Microhard carrier boards are doing their jobs as the correct network interfaces are appearing.
Have you ever been able to establish a connection between these two Microhard modules in the past? It's possible that one or both are faulty.
And just to confirm, on the standalone side you are using antennas as well correct?
@tom This is the image showing LED behaviour.
From the bottom
- Lnk/ACT : OFF
- Lnk/100 : ON
- Lnk : ON
- CPU : ON
- RSSI_1, RSSI_2, RSSI_3 : blinking one after another
- RX : ON (continuous)
- TX : Blinking (low)
Note: One thing I noticed now is that the Standalone microhard unit we have is 128 bit AES encryption model, where the Modal AI add-on module is showing 256 bit AES encryption model. Do you think this is the reason they are not communicating? All the microhard unit we have here is 128 bit AES model. If that is the case how can we access the Add-on Microhard unit?
@tom I was able to access the web interface by plugging the Add-on Microhard unit into a development board. And indeed I found the Network ID is mismatched and was set to as
pMDDLinstead ofpDDL. Also the frequency was set to76-2477which is okay since I tried with multiple band with the slave unit as well. See the default configuration of the Add-on unit before changing
