Thasindu WickramaT
Thasindu Wickrama
@Thasindu Wickrama
  • Clarification on Livox Mid 360 LiDAR Compatibility with VOXL 2 on Starling 2 Max Outdoor Drone
    Thasindu WickramaT Thasindu Wickrama
    @Eric-Katzfey we are planning to integrate it with ros. Physical connection through the extension board ethernet port.
    ESCs, Sensors and Accessories
    @Moderator does the c29 variant includes the thermal camera? Its not clear as per the webpage information.
    @Eric-Katzfey have you tried any other lidar (2D or 3D one) with the voxl board?
    Hello ModalAI Team,
    I am currently planning to work with the Starling 2 Max Outdoor Drone and looking into integrating a Livox Mid 360 LiDAR for mapping purposes. I would like to clarify the following:
    1. Does the VOXL 2 on the Starling 2 Max support the mounting and operation of the Livox Mid 360 LiDAR?
    2. If not natively supported, is there a recommended interface or adapter to establish compatibility?
    3. Is there a USB extension or specific cable available to connect the Livox Mid 360 to the VOXL 2, considering the power and data transmission requirements?
    I appreciate any guidance or documentation you can provide on this integration.
    Thank you!
