Rolando FernandezR
Rolando Fernandez
@Rolando Fernandez
  • Need newer version of GCC on VOXL
    Rolando FernandezR Rolando Fernandez
    @Chad-Sweet How do I get my build in docker to locate the voxl libraries on the system? For example, the voxl_io header.
    VOXL SDK and Software
    @Chad-Sweet How do I get the docker system services to start on boot?
    Also, does the docker image have full access to all the peripherals on the system? Basically, does voxl-docker run images in privileged mode?
    @Chad-Sweet Do you have an example of running docker onboard and how I can transfer a docker image to the voxl?
    Is the issue regarding docker image size been resolved? I know awhile back Steve was trying to use docker but he was having trouble with our image being too large to run on the voxl.
    I work over at ARL with Steve Nogar. I have some software I want to run on the VOXL that has a hard requirement of C++17 but the version of GCC on the VOXL does not support C++17. I tried compiling a version of GCC (v7 or newer) that supports C++17 native on the VOXL but it fails due to some assembler errors.
    Is there any way to get a newer version of GCC for the VOXL system?
    Thanks,
    Rolando
