Rawdha RR
Rawdha R
@Rawdha R
  • Gstreamer error: Streaming video to QGC over LTE
    Rawdha RR Rawdha R
    @tom
    P.S. I am currently working with the Drone Sentinel VOXL 2 and the drone is connected via LTE but without Wi-Fi, because there is no wifi dongle.
    Rawdha RR Rawdha R
    @tom
    The issue still persists for me. Do you think my setup could be causing the problem? I have an M1 Mac processor, and I'm using a virtual machine with UTM(Visualizer). Could that be causing any limitations? Should I try a different setup, and do you have any recommendations?
    Rawdha RR Rawdha R
    @tom
    I think I need a wifi dongle for it and I haven’t tried it with wifi.
    Rawdha RR Rawdha R
    @tom
    No, I’m not able to pull up the stream in VLC, I’m getting this error:
    Rawdha RR Rawdha R
    @Zachary-Lowell-0
    @tom
    No worries, I reverted the voxl-streamer configuration to its original settings, restarted it, then updated and restarted voxl-mavcam-manager.conf.
    Afterwards, I attempted to set the RTSP stream to the specific IP address:
    When I checked voxl-streamer, the output showed the following:
    This is the errors that I got from Qground:
    Rawdha RR Rawdha R
    @Zachary-Lowell-0 @tom
    I have configured Tailscale as a priority network:
    While setting up the voxl-streamer (located at /etc/modalai/voxl-streamer.conf) with the new URL, I noticed that the parameters auto_ip and url were missing:
    I have added both parameters, setting auto_ip to false and updating the url with the Tailscale IP address and I checked the voxl-streamer and found that the stream value is still showing as 127.0.0.1:
    After these adjustments and power cycling the device, Additionally, I attempted to check the connection in QGroundControl and VLC, but I'm encountering some errors:
    Rawdha RR Rawdha R
    @Zachary-Lowell-0
    @tom @groupo
    The setup is working well. I successfully pinged both the VOXL drone and the parent computer:
    Additionally, I managed to stream using MVP, and it functioned:
    As for the wwan0, I have confirmed that an IP address is displayed:
    Both voxl-streamer and voxl-camera-server is enabled and running:
    However, I'm still encountering some difficulties with streaming on VLC and QGroundControl (QGC). I've installed the necessary GStreamer dependencies, but I continue to receive errors when attempting to stream on both platforms.
    I have following the instructions in this link to install gstreamer properly:
    https://gstreamer.freedesktop.org/documentation/installing/on-linux.html?gi-language=c
    P.S: I'm using Ubuntu 22.04.5 LTS
    Rawdha RR Rawdha R
    I have connected QGroundControl (QGC) to my VOXL 2 using a 5G modem and Tailscale VPN. However, I am unable to stream the camera feeds.
    Additionally, I tried using VLC, but I’m not receiving the video stream. Here are the error messages I am encountering in both QGC and VLC:
    Screen Shot 2024-10-07 at 10.52.07 AM.png ![Screen Shot Screen Shot 2024-10-07 at 10.52.44 AM.png Screen Shot 2024-10-07 at 10.55.41 AM.png
  • issue with starting the cameras on my VOXL 2 device.
    Rawdha RR Rawdha R
    @tom It worked! I tightened the screws, and it turns out it was a hardware issue. I've installed the Tailscale VPN on both the drone and my machine, and I've completed the calibration and binding. However, I'm having trouble starting the camera; it's not turning on in VLC or QGroundControl.
    Rawdha RR Rawdha R
    @tom
    I have double-checked that the 5G add-on board is fully seated, and I followed the same process that worked successfully before the update. Given the current issue, what would you recommend I check next to help resolve this? I have attached a screenshot where I tried to reconfigured the modem and the issue still persists.
    Rawdha RR Rawdha R
    @tom
    This is what I got when I tried ifconfig there is no wwan0 in the list
    Rawdha RR Rawdha R
    @tom I'm having trouble pinging the drone. I've set it up using a 5G modem (since the drone that I have doesnt have a wifi dongle) [VOXL AL & 5G Development drone-sentinel 5G LTE Modem] to connect to QGroundControl and proceed with installing the VPN on the drone. However, when I attempt to ping google.com, I get an error stating "unknown server," and I'm unable to see the drone's IP address. Prior to updating the SDK, I had successfully configured the modem and connected to QGroundControl via Tailscale VPN and I don't know why I'm getting these issues now. Any assistance in resolving this issue would be appreciated.
    Rawdha RR Rawdha R
    @tom
    It worked! I have attached a screenshot of the update:
    Rawdha RR Rawdha R
    @tom
    I followed your instructions and ran sudo dmesg -wH to monitor the kernel messages while reproducing the issue. I observed the output, which I’ve attached as a screenshot.
    For context, I am running Ubuntu on a virtual machine (VM) and not directly on my hardware. I attempted the first flight of the drone, (VPN Tailscale) and while everything else was running smoothly, the only issue I faced was that the cameras did not turn on.
    Rawdha RR Rawdha R
    @tom Yes the permissions are there, I have attached a screenshot of the permissions. In the previous post sceenshot it shows as "[INFO} Found fastboot device", but once I send 1 and enter it's stuck. Screen Shot 2024-09-10 at 8.45.51 AM.png
    Rawdha RR Rawdha R
    @tom said in issue with starting the cameras on my VOXL 2 device.:
    @Rawdha-R I think the best first step would be to load the latest SDK on your VOXL 2 as that SDK is a few years old at this point.
    I would recommend flashing the latest SDK (1.3.3) from downloads.modalai.com under "VOXL 2 Platform Releases"
    Just follow the instructions here to do so: https://docs.modalai.com/flash-system-image/#flashing-a-voxl-sdk-release
    I tried flashing the latest SDK (1.3.3) from downloads modalai under VOXL 2 platform release[link text]Screen Shot 2024-09-09 at 9.59.59 AM.png It is stuck at this point, please see the screenshot above.
  • Missing `voxl-inspect-sku` Command and Repository Issues
    Rawdha RR Rawdha R
    @tom this is the output: Vol version: --------------------------------------------------------------------------------
    system-image: 1.3.1-M0054-14.1a-perf
    kernel: #1 SMP PREEMPT Tue Aug 2 05:23:05 UTC 2022 4.19.125
    hw version: M0054
    voxl-suite: 0.8.1
  • voxl-camera-server only showing hires
    Rawdha RR Rawdha R
    When accessing the VOXL web portal, only the "Hires" camera is visible. Previously all 7 cameras where visible(Hires, Tracking, Qvio Overlay, Stereo Front (2 cameras), Stereo Rear (2 cameras))
    This is the output for voxl-configure-cameras:
    voxl2:/$ voxl-configure-cameras
    ERROR: missing camera config ID
    For more flexibility, use the general use case:
    voxl-configure-cameras <configuration-id>
    arguments are as follows:
    sentinel - default for sentinel drone, no config ID needed
    disable - disables voxl-camera-server
    help - show this help text
    If no configuration-id or arguments are given, the user will be
    prompted with questions to help complete configuration
    available camera configurations are as follows:
    0 None
    1 Tracking + Stereo(OV7251)
    2 Tracking Only
    3 Hires + Stereo(OV7251) + Tracking
    4 Hires + Tracking
    5 TOF + Tracking
    6 Hires + TOF + Tracking
    7 TOF + Stereo(OV7251) + Tracking
    8 Hires Only
    9 TOF Only
    10 Stereo(OV7251) only
    11 Tracking + Hires + Dual Stereo Pairs
    12 Stereo(OV9782) only
    13 Hires + Stereo(OV7251)
    voxl-camera-server has only hires configured, I tried configuring the rest of the cameras but got the following error: voxl2:/$ sudo systemctl status voxl-camera-server
    \u25cf voxl-camera-server.service - voxl-camera-server
    Loaded: loaded (/usr/bin/voxl-camera-server; enabled; vendor preset: enabled)
    Active: failed (Result: signal) since Wed 2024-09-04 06:35:09 UTC; 4s ago
    Process: 28196 ExecStart=/bin/bash -c /usr/bin/voxl-camera-server (code=killed
    Main PID: 28196 (code=killed, signal=SEGV)
    Sep 04 06:35:09 m0054 bash[28196]: Error in json_read_file while parsing file /e
    Sep 04 06:35:09 m0054 bash[28196]: The syntax error occured immediately BEFORE t
    Sep 04 06:35:09 m0054 bash[28196]: 412",
    Sep 04 06:35:09 m0054 bash[28196]: ERROR: object missing cameras
    Sep 04 06:35:09 m0054 bash[28196]: Segmentation fault:
    Sep 04 06:35:09 m0054 bash[28196]: Fault thread: voxl-camera-ser(tid: 28196)
    Sep 04 06:35:09 m0054 bash[28196]: Fault address: 0x10
    Sep 04 06:35:09 m0054 bash[28196]: Address not mapped.
    Sep 04 06:35:09 m0054 systemd[1]: voxl-camera-server.service: Main process exite
    Sep 04 06:35:09 m0054 systemd[1]: voxl-camera-server.service: Failed with result
    lines 1-16/16 (END) I triedd to reconfigure according to the following types but I'm still getting an error. (type: “ov7251”, “ov9782”, “imx214”, “imx412”, “imx678”, or “pmd-tof” )
    Rawdha RR Rawdha R
    I am experiencing issues with my VOXL 2 device. Specifically, the voxl-inspect-sku command is not found on my system. Additionally, I am encountering problems with the ModalAI repository configuration which might affect package installations.
    Here are the details:
    • The command voxl-inspect-sku is missing, and I am unable to locate or install it.
    • The repository configuration is as follows:
