M
mr TOKI
@mr TOKI
  • offboard mode in voxl m500
    M mr TOKI
    @modaltb said in offboard mode in voxl m500:
    l-vision-px4 program
    Oh I see, I had tried it worked with marvos, in offboard mode. But the altitude of voxl m500 was incorrect 1.jpg
    In my code, I set altitude is 0.3m and QGC show exactly (in POSITION_TARGET_LOCAL_NED) but m500 flew up to 0.5m, and sometime it sliped from home_position. Do you have any solution ??
    M mr TOKI
    @modaltb I had been used MAVROS example but before that I change offboard_mode to OFF as this picture 7e9e151b-1439-4d2e-9b24-96cbdd23924a-image.png
    M mr TOKI
    I still get some problem, first I change offboard_mode in config to OFF then I use my mavros file but it seem didn't work right. The UAV can only arm then disarm. when I check in Qgroundcontrol, I couldn't change to Offboard mode.I had tried again but it still didn't change. How to solve this problem??
    Thank you
    M mr TOKI
    Thanks for the fast reply.
    I want to use my own offboard mode so I change figure_eight in file config to OFF but when I tested QGC can't turn to offboard mode ??
    M mr TOKI
    Hello.
    I am just wondering, in offboard mode there are any mode that difference than figure_eight ?? If not how I can write and add my own offboard mode to voxl m500.
    Thank you!!!
  • Help! lossing data from camera + IMU tracking
    M mr TOKI
    @Vũ-Văn-Long wow amazing goodjob
    Development Drones m500
  • Change Altitude of Take-off mode
    M mr TOKI
    oh I see thank you. And do you know how much weight that VOXL m500 drone can lift. Thank you !!!
    M mr TOKI
    Hello !! I followed VOXL m500 instruction changed QGC to Position Mode . When I use takeoff mission but I can not change the Altitude
    of takeoff mission (I had changed to 0.5 m but the UAV still head up to 2.5m )
    Please show me how to change the alt
  • Can' connect between FrSKY D4R-II and flight core m500
    M mr TOKI
    @modaltb said in Can' connect between FrSKY D4R-II and flight core m500:
    X8R
    I wired as picture and followed the doc as you send. But I still can't use my transmiter to control it eventhough led from RC was green. I still can't find the problem . Please help me
    M mr TOKI
    @modaltb oh I see. Thank you and I will try to do it
    M mr TOKI
    https://drive.google.com/drive/folders/1B42BBlrNK3JpkPtAO92ZF6bj5B3BVaDL?usp=sharing
    M mr TOKI
    I have been try to connect another reciever from FrSky to Flight Core of Voxl m500 but it seem didn't work rigtht . My reciever had been binded with transmiter but when I run QGroundControl and use transmiter to control , QGC didn't have any signal .
