@tom
My video link has a weak signal. How can I improve the signal to achieve a 4K video stream for Q Ground Control? Additionally, I have another question: I'm using a 5G SIM card, but when I connect it to the modem, my PC doesn't receive internet.
Posts made by M. al-khatib
RE: 5G modemposted in Sentinel
@tom
How can I determine the type of network (3G, 4G, 5G) that I'm currently connected to, and shouldn't the modem grant me an internet connection when I'm in the process of connecting to it? -
After using this commands and connect my PC to Tailscale what can i do ?
RE: No GPs lock for vehicleposted in Sentinel
@Eric-Katzfey
Okay, I'm done, and the drone got GPS this is video link.
https://drive.google.com/file/d/1XfcMhyPKbJYDFnPwljM3zM7MbZWcx4op/view?usp=sharing
However, I mistakenly used the power adapter instead of the battery when I unplugged it to switch to flight on battery mode, so there was no GPS signal.
my sdk now is 1.0.0
and my firmware Version 1.14.0dev -
@Eric-Katzfey said in No GPs lock for vehicle:
px4-versions
modalai-slpi/now 1.0-7 arm64 [installed,local]
px4-rb5-flight/now 1.4-11 arm64 [installed,local]
px4-support/now 1.0-5 arm64 [installed,local]
python3-px4sitl/bionic 0.0.2-100 all
ros-melodic-px4-msgs/bionic 1.0.0-1bionic.20210505.094529 arm64
voxl-px4-imu-server/unknown,now 0.1.1 arm64 [installed,automatic]
voxl-vision-px4/unknown,now 1.0.5 arm64 [installed,automatic]
libfc-sensor/now 1.0-2 arm64 [installed,local]
1.2.1-M0054-14.1a-perf -
@M-al-khatib
While presently utilizing the exact same parameter, the QGS occasionally presents a GPS error, whereas at other instances, it indicates normal GPS functionality.
@Eric-Katzfey
I have now arrived at this stage, yet my GPS count remains at zero.
@Eric-Katzfey
"I can't find the command 'qshell gps start -d 7 -b 115200' or 'qshell gps start' in the file '/etc/modalai/voxl-px4.config'." -
@Eric-Katzfey
my test.txt file same as the Samer Jaradat file. -
@modaltb said in No GPs lock for vehicle:
Hi @M-al-khatib , unless I move my vehicle outside and it has a view of the sky does the GPS get satellites. Are you trying to do the GPS test in an environment that isn't 'shielded' like indoors?
Yes, I conducted an outdoor test with specific parameters, focusing on essential factors. The test revealed that there was no GPS signal for the vehicle, and the information indicated that the GPS functionality was disabled. Throughout the test, the GPS count consistently remained at zero, with no HDOP readings available.
