Hi again,
Thank you for the clarification on the battery specs and for highlighting the risks.
Given that the original motor (1504 3000KV, PN: M10000633) is now officially obsolete/end-of-life (as shown in your product specs) and replaced by M10001231, we will strictly follow your advice and avoid any hardware hacks or mixing different motor specs.
PNG
However, having to replace three perfectly operational motors simply because the single original part was discontinued leaves us in a difficult position for a routine repair.
Since we need a reliable and official path forward to get our Starling 2 flying again, could you please advise on how ModalAI handles this situation?
EOL Support / Single Motor Solution: Is there any remaining stock of the original M10000633 motor for RMA/repair cases, or any official solution to avoid replacing the entire set of 4 motors when only one is damaged?
Official Replacement Path: If replacing all 4 motors with the 1503 2900KV (M10001231) model is strictly mandatory, do you offer a replacement bundle/discount for users impacted by this EOL transition?
Firmware / PID Configuration: If we are forced to replace all 4 motors with the 1503 2900KV model, does ModalAI provide an updated PX4/VOXL parameters file/tune for this hardware revision, or does the default factory tune handle the change automatically?
We appreciate your guidance to ensure our autonomous flight testing remains safe, supported, and cost-effective.
Best regards,
