Jerry LinJ
Jerry Lin
@Jerry Lin
  • Collision Prevention doesn't work with all health checks passed
    Jerry LinJ Jerry Lin
    Hi, our team followed the VOA instructions to try the important features needed in our projects and it appears "Collision Prevention" doesn't work like the video demonstrated and we still can get our Sentinel very close (around 2 inches) to walls or trees. The only thing possibly wrong is we don't get OBSTACLE_DISTANCE message in QGC. Otherwise, we can see all stereo_front_pc, stereo_rear_pc and voa_pc_out point clouds in voxl-portal with voxl-dfs-server running, Health Check and voxl system check in voxl-portal all passed and object detection enabled for different Minimum Distances.Screenshot 2024-12-03 at 2.01.13 PM.png and CP_* parameters verifiedScreenshot 2024-12-03 at 2.06.31 PM.png:
    Is no OBSTACLE_DISTANCE message a real issue? If not, any clue about what can go wrong?
    Any clue how to debug?
    Development Drones sentinel
  • My Sentinel crashed during simple missions with "Failsafe activated, triggering descend"
    I suspected probably it is because of the fused local position by vision and searched in parameter. It sounds EKF2_GPS_CTRL is probably relevant. So, I set it to be 0 from 7. After trying that, my outdoor missions were all smooth without any accident.
    I then set it back to 7 and tried flying in position mode. This error happened again and with altitude mode was forced.
    So, anybody here know how to fix the problematic local position estimate? This is an AI drone and it shouldn't perform worse than drones without any vision.
    Hi, here is the full messageScreenshot 2024-11-07 at 4.28.28 PM.png.
    Also sometimes the following was encountered: Screenshot 2024-11-07 at 5.13.00 PM.png.
    When I tried few simple missions, not sure why this happened only at certain points or certain directions? Also not sure why both local and global position estimates failed at the same time?
  • Quectel 5G-Modem doesn't work at all
    OK, cool 👍 thanks❗
    Will try.
    BTW, what are the routing changes suggested? Do I need to execute any commands? Or, do they happen automatically by some code or scripts?
    I
    • checked with an AT&T store and they provide SIM card for phone only.
    • then googled around and found several attempts using Quectel MODEM with AT&T SIM card and AT commands were used for debugging.
    • searched in ModalAI Forum and found some AT commands for the model.
    • tried but got only ERROR
      voxl2:~$ echo -ne "AT+QNWPREFCFG="mode_pref",LTE:NR5G\r" | busybox microcom /dev/ttyUSB2
      AT+QNWPREFCFG=mode_pref,LTE:NR5G
      ERROR
    • did voxl-configure-modem again to see if AT commands can be used and found the same command:
      Sep 25 02:41:22 m0054 voxl-modem-start[8392]: qrb5165 based hardware detected...
      Sep 25 02:41:22 m0054 voxl-modem-start[8392]: \Setting mode preference to LTE / 5G
      Sep 25 02:41:22 m0054 voxl-modem-start[8392]: AT+QNWPREFCFG="mode_pref",LTE:NR5G
      Sep 25 02:41:22 m0054 voxl-modem-start[8392]: OK
      Sep 25 02:41:23 m0054 voxl-modem-start[8392]: Initalizing cellular connection...
    • After 7 minutes I saw: no lease, failing. Well, at least, it tried to lease.
      Sep 25 02:48:49 m0054 voxl-modem-start[8392]: udhcpc: started, v1.27.2
      Sep 25 02:48:49 m0054 voxl-modem-start[8392]: No resolv.conf for interface wwan0.udhcpc
      Sep 25 02:48:49 m0054 voxl-modem-start[8392]: udhcpc: sending discover
      Sep 25 02:48:52 m0054 voxl-modem-start[8392]: udhcpc: sending discover
      Sep 25 02:48:55 m0054 voxl-modem-start[8392]: udhcpc: sending discover
      Sep 25 02:48:58 m0054 voxl-modem-start[8392]: udhcpc: sending discover
      Sep 25 02:49:01 m0054 voxl-modem-start[8392]: udhcpc: sending discover
      Sep 25 02:49:04 m0054 udhcpc[10399]: wwan0: configuration failed: leasefail:
      Sep 25 02:49:04 m0054 voxl-modem-start[8392]: udhcpc: no lease, failing
    • All of sudden, I saw lease obtained with an IP provided:
      Sep 25 02:49:04 m0054 voxl-modem-start[8392]: udhcpc: started, v1.27.2
      Sep 25 02:49:05 m0054 voxl-modem-start[8392]: No resolv.conf for interface wwan0.udhcpc
      Sep 25 02:49:05 m0054 voxl-modem-start[8392]: udhcpc: sending discover
      Sep 25 02:49:05 m0054 voxl-modem-start[8392]: udhcpc: sending select for 10.194.135.84
      Sep 25 02:49:05 m0054 voxl-modem-start[8392]: udhcpc: lease of 10.194.135.84 obtained, lease time 7200
      Sep 25 02:49:05 m0054 voxl-modem-start[8392]: Too few arguments.
    • I was not sure about the impact of Too few arguments error, though.
    Well, with an IP address, I tried to:
    • ping
    • ssh
    Unfortunately only responded with timeout messages.
    Wondering if I really have the Internet access, I did ifconfig wlan0 down and the ping google.com from voxl. It was still responded !!!
    Hmm, how about continue Connecting to QGC over 5G instructions?
    • With Tailscale VPN installed, I was able to ssh to the drone using the VPN IP address!!!
    • With QGroundControl setup, I was able to see the drone statuses and statistics using the VPN IP address!!!
    That means I can control the drone even it is hundreds of miles away!!!
    Millions of thanks for great help @tom and @Vinny !!!!!!!!!!!
    Still with Too few arguments error, I am not sure how good the 4G/5G connection would be. Will experiment more to figure out. However, if you guys know anything can be improved, please let me know.
    OK, will get to carries to see if I can move forward with the existing SIM cards. If not, will try Google Fi IoT SIM cards.
    Thanks for the advice!!!
    Cool, my carriers are AT&T and Xfinity Mobile. What I should I mention to them for my application? Just IoT or any specs that you know about?
    So, the log:
    voxl2:~$ quectel-CM -s nxtgenphone
    [09-10_01:27:54:793] Quectel_QConnectManager_Linux_V1.6.0.24
    [09-10_01:27:54:795] Find /sys/bus/usb/devices/2-1.1 idVendor=0x2c7c idProduct=0x800, bus=0x002, dev=0x003
    [09-10_01:27:54:795] Auto find qmichannel = /dev/cdc-wdm0
    [09-10_01:27:54:795] Auto find usbnet_adapter = wwan0
    [09-10_01:58:12:576] requestSetupDataCall message timeout
    [09-10_01:58:12:576] requestSetupDataCall err = 110
    [09-10_01:58:12:576] try to requestSetupDataCall 60 second later
    [09-10_01:59:12:615] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
    [09-10_01:59:12:615] try to requestSetupDataCall 60 second later
    looks a SIM card issue to you? Or what else (e.g. commands or wiring) can I try to get 5G connected?
    @tom said in Quectel 5G-Modem doesn't work at all:
    It's possible you need a SIM card specifically for IOT devices from your carrier
    So, did you mean normal phone SIM cards are not compatible with the Quectel modem and the "5G LTE" is not the same protocol our phones use as advertised "Connectivity: 4G/5G"?
    Then, what are requirements should I provide to my carrier (located in Pennsylvania, USA) for this kind of SIM card to get the drone Internet access?
    Sure, will do.
    Sorry that I was trying to insert the SIM card and realized unable to do it unless lifting the modem module. After inserting the SIM card, I didn't push hard worrying breaking anything because the drone is super expensive.
    Thanks to Tom for helping me understand how the modules are connected. I think inserting the SIM card is a very frequent activity and it would be nice to make it very accessible by a hole like others on the side. It took me hours to figure out how to access the SIM card socket. Anyway, now I learned how to secure the connections and not a problem for me anymore.
    BTW, any idea about my last "timeout and trying forever" issue? I have tried two SIM cards without a success.
    Super cool, after all unscrewed and the modem taken out, I saw the connectors. Knowing how they connect, I pressed hard to make sure fully seated and the qmidevice_detect failed went away with the WiFi working!!!
    The output of lsusb looks more devices now:
    voxl2:~$ lsusb
    Bus 002 Device 003: ID 2c7c:0800
    Bus 002 Device 002: ID 0424:5744 Standard Microsystems Corp.
    Bus 001 Device 004: ID 0424:2740 Standard Microsystems Corp.
    Bus 001 Device 003: ID 0bda:0811 Realtek Semiconductor Corp.
    Bus 001 Device 002: ID 0424:2744 Standard Microsystems Corp.
    The output of quectel-CM is now totally different:
    [09-10_01:27:54:795] netcard driver = qmi_wwan, driver version = 22-Aug-2005
    [09-10_01:27:54:796] Modem works in QMI mode
    [09-10_01:27:54:828] /proc/3149/fd/7 -> /dev/cdc-wdm0
    [09-10_01:27:54:828] /proc/3149/exe -> /usr/bin/quectel-CM
    [09-10_01:27:56:830] cdc_wdm_fd = 7
    [09-10_01:27:56:905] Get clientWDS = 1
    [09-10_01:28:26:908] QmiWwanGetClientID message timeout
    [09-10_01:28:26:921] Get clientNAS = 4
    [09-10_01:28:26:953] Get clientUIM = 1
    [09-10_01:28:26:985] Get clientWDA = 1
    [09-10_01:28:26:985] QMIType 2 has no clientID
    [09-10_01:28:26:985] requestBaseBandVersion err = -19
    [09-10_01:28:41:321] QmiWwanThread read=-1 errno: 2 (No such file or directory)
    [09-10_01:28:56:987] requestSetEthMode message timeout
    [09-10_01:28:56:987] requestSetEthMode err = 110
    [09-10_01:29:26:989] requestGetSIMStatus message timeout
    [09-10_01:29:26:990] requestGetSIMStatus err = 110
    [09-10_01:29:26:990] requestSetProfile[1] nxtgenphone///0
    [09-10_01:29:27:081] QmiWwanThread read=-1 errno: 2 (No such file or directory)
    [09-10_01:29:57:051] requestGetProfile message timeout
    [09-10_01:29:57:051] requestGetProfile err = 110
    [09-10_01:29:57:064] QmiWwanThread read=-1 errno: 2 (No such file or directory)
    [09-10_01:30:27:054] requestRegistrationState2 message timeout
    [09-10_01:30:27:055] requestRegistrationState2 err = 110
    [09-10_01:30:57:056] requestQueryDataCall message timeout
    [09-10_01:30:57:057] requestQueryDataCall err = 110
    [09-10_01:30:57:057] ifconfig wwan0 0.0.0.0
    [09-10_01:30:57:083] ifconfig wwan0 down
    [09-10_01:30:57:129] requestRegistrationState2 MCC: 310, MNC: 410, PS: Attached, DataCap: LTE
    [09-10_01:32:57:130] requestSetupDataCall message timeout
    [09-10_01:32:57:130] requestSetupDataCall err = 110
    [09-10_01:32:57:130] try to requestSetupDataCall 5 second later
    [09-10_01:35:02:132] requestSetupDataCall message timeout
    [09-10_01:35:02:133] requestSetupDataCall err = 110
    [09-10_01:35:02:133] try to requestSetupDataCall 10 second later
    [09-10_01:35:12:170] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
    [09-10_01:35:12:170] try to requestSetupDataCall 20 second later
    [09-10_01:35:32:200] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
    [09-10_01:35:32:200] try to requestSetupDataCall 40 second later
    [09-10_01:38:12:226] requestSetupDataCall message timeout
    [09-10_01:38:12:228] requestSetupDataCall err = 110
    [09-10_01:38:12:228] try to requestSetupDataCall 60 second later
    [09-10_01:41:12:274] requestSetupDataCall message timeout
    [09-10_01:41:12:277] requestSetupDataCall err = 110
    [09-10_01:41:12:277] try to requestSetupDataCall 60 second later
    [09-10_01:44:12:304] requestSetupDataCall message timeout
    [09-10_01:44:12:304] requestSetupDataCall err = 110
    [09-10_01:44:12:304] try to requestSetupDataCall 60 second later
    [09-10_01:45:12:357] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
    [09-10_01:45:12:357] try to requestSetupDataCall 60 second later
    [09-10_01:46:12:424] QmiWwanThread read=-1 errno: 2 (No such file or directory)
    [09-10_01:48:12:391] requestSetupDataCall message timeout
    [09-10_01:48:12:391] requestSetupDataCall err = 110
    [09-10_01:48:12:392] try to requestSetupDataCall 60 second later
    [09-10_01:49:12:454] requestSetupDataCall QMUXResult = 0x1, QMUXError = 0x1a
    [09-10_01:49:12:454] try to requestSetupDataCall 60 second later
    [09-10_01:52:12:486] requestSetupDataCall message timeout
    [09-10_01:52:12:486] requestSetupDataCall err = 110
    [09-10_01:52:12:486] try to requestSetupDataCall 60 second later
    [09-10_01:55:12:530] requestSetupDataCall message timeout
    [09-10_01:55:12:533] requestSetupDataCall err = 110
    [09-10_01:55:12:533] try to requestSetupDataCall 60 second later
    [09-10_01:56:12:582] QmiWwanThread read=-1 errno: 2 (No such file or directory)
    However, it takes forever to finish. I googled around my AT&T APN, it looks right using nxtgenphone:
    If you have an:
    LTE device: Set your settings to NXTGENPHONE
    Data device: Set your settings to Broadband
    5G Smartphone: Set your settings to ENHANCEDPHONE
    Not sure what is going wrong this time.
    Hi @tom I am not sure and don't know how.
    Can you show me some pictures so I can have the clue which modules are needed take apart for checking and making sure.
    Sure,
    I didn't touch anything except for opening the cover, unscrewing the nuts and inserting the SIM card.
    The weird thing is every time I insert the SIM card, my WiFi will be gone without even the blue flash light from the WiFi module.
    Then, it took me long to get WiFi back by reconnecting the wire, touching around Quectel module, restarting dhcpcd and disabling voxl-modem, anything I can think of related to wlan0.
    After having WiFi, lsusb would output:
    While having more USB devices, I tried voxl-configure-modem without the SIM card, I still got
    [09-08_07:06:58:832] Quectel_QConnectManager_Linux_V1.6.0.24
    [09-08_07:06:58:832] network interface '' or qmidev '' is not exist
    [09-08_07:06:58:832] qmidevice_detect failed
    [09-08_07:06:58:833] qmidevice_detect failed
    Hi @tom, here are the outputs:
    voxl2:/$ lsusb
    voxl2:/$ lsusb -t
    /:  Bus 02.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 10000M
    /:  Bus 01.Port 1: Dev 1, Class=root_hub, Driver=xhci-hcd/1p, 480M
    Hi, I followed 5G Modem User Guide
    voxl2:/$ voxl-configure-modem
    Starting interactive mode
    1) v2	      3) dtc	    5) quectel
    2) microhard  4) doodle	    6) em9191
    #? 5
    1) yes
    2) no
    #? 2
    Verizon - APN: vzwinternet
    Google Fi - APN: h2g2
    1) m2m.com.attz	      4) fast.t-mobile.com  7) Custom
    2) broadband	      5) vzwinternet
    3) phone	      6) googlefi
    #? 7
    Please enter a custom APN
    nxtgenphone
    Select modem region:
    1) Americas
    2) Europe/Middle-East/Asia
    #? 1
    qrb5165 based device detected
    reloading systemd services
    DONE configuring voxl-modem
    and it always failed with:
    voxl2:/$ systemctl status -l voxl-modem
    ● voxl-modem.service - Modem Initialization
       Loaded: loaded (/etc/systemd/system/voxl-modem.service; enabled; vendor preset: enabled)
       Active: active (running) since Sun 2024-09-08 07:03:55 UTC; 14s ago
      Process: 3019 ExecStartPre=/bin/sleep 2 (code=exited, status=0/SUCCESS)
     Main PID: 3020 (voxl-modem-star)
        Tasks: 2 (limit: 4915)
       CGroup: /system.slice/voxl-modem.service
               └─3020 /bin/bash /usr/bin/voxl-modem-start
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:955] qmidevice_detect failed
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:956] Quectel_QConnectManager_Linux_V1.6.0.24
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:957] network interface '' or qmidev '' is not exist
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:957] qmidevice_detect failed
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:961] Quectel_QConnectManager_Linux_V1.6.0.24
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:961] network interface '' or qmidev '' is not exist
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:961] qmidevice_detect failed
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:963] Quectel_QConnectManager_Linux_V1.6.0.24
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:963] network interface '' or qmidev '' is not exist
    Sep 08 07:03:56 m0054 voxl-modem-start[3020]: [09-08_07:03:56:963] qmidevice_detect failed
    I checked this forum and tried the following command
    The result was still the same.
    I tried the latest voxl-modem and still no luck.
    I purchased Sentinel with 5G LTE modem without touching anything. I double checked the Quectel modem after inserting the SIM and confirmed it is secured as before.
    Can anybody help resolve this issue?
