Hi, I’m posting a problem we are experiencing with a Voxl2.
Whenever Hires or Tracking cameras are connected to C2, and C3 connected to J6, J7 or J8, then Voxl is not responding and the ribbon cable gets extrtemely hot.
Connecting one of the cameras to C1, and C3 to J6, J7 or J8 then Voxl runs but cable gets also very hot (not like the previous one though).
Similar behaviour using the M0076 adapter in order than M0084.
None of the combinations give us a camera image.
Test is performed with old Hires, Tracking and M0084 adaper and also with a new set (Hires, Tracking and M0084 adapter) directly taken from the package. Results are the same in both scenarios.
Voxl seems to be damaged but I’m asking for help in order to acurate more the problem and hopefully try find a solution, but sincerely It does not look good.
Thank you so much in advance!
Best Regards!
