J DataJ
J Data
@J Data
  • Implementing PX4 avoidance in mission mode using the voxl and QGC
    J DataJ J Data
    @modalab Hello, can you help me to resolve this problem?
    J DataJ J Data
    @Chad-Sweet , No matter the tf setting in the urdf file is, the ros topic outputs are shown in the followings
    1. rostopic echo mavros/imu/data (in base_link frame): x is backward, y is right, z is down
    2. rostopic echo downward/imu (in imu frame): x is right, y is backward, z is down
    J DataJ J Data
    @Chad-Sweet
    I am using customized urdf for snap_vio which has different numbers (positions and orientations) of sdf_pro.urdf.
    Is there any urdf file for VOXL?
    J DataJ J Data
    @Chad-Sweet
    Update.
    I have output /downward/vio/odometry with some error messages
    [ INFO] [1648150781.892213161]: [VISLAM] Got uav1/imu to uav1/dfc transform; Initializing VISLAM
    [ INFO] [1648150781.892816862]: [VISLAM] (from tf) tbc:
    x: 0.2
    y: 0
    z: -0.025
    [ INFO] [1648150781.893485304]: [VISLAM] (from tf) ombc:
    X: 0
    Y: 2.356
    Z: 0
    MachineVision is licensed as community user
    LNX_8074 supported? 1
    LNX_8096 supported? 1
    LNX_IA64 supported? 1
    WINDOWS supported? 0
    AR ERROR: arFileOpen(): Failed to open file: /data/.ros/vislam/Configuration.SF.xml
    FASTCV: fcvAvailableHardware Linux
    mempool cur block size 307200, new block size 307200
    AR ERROR: arFileOpen(): Failed to open file: /data/.ros/na
    Error:   TF_NAN_INPUT: Ignoring transform for child_frame_id "grav" from authority "unknown_publisher" because of a nan value in the transform (0.000000 0.000000 0.000000) (-nan -nan -nan nan)
             at line 244 in ~/geometry2/tf2/src/buffer_core.cpp
    Error:   TF_DENORMALIZED_QUATERNION: Ignoring transform for child_frame_id "grav" from authority "unknown_publisher" because of an invalid quaternion in the transform (-nan -nan -nan nan)
             at line 257 in ~/geometry2/tf2/src/buffer_core.cpp
    [ERROR] [1648150782.073463584]: Ignoring transform for child_frame_id "grav" from authority "unknown_publisher" because of a nan value in the transform (0.000000 0.000000 0.000000) (-nan -nan -nan nan)
    [ERROR] [1648150782.077556213]: Ignoring transform for child_frame_id "grav" from authority "unknown_publisher" because of an invalid quaternion in the transform (-nan -nan -nan nan)
    [ERROR] [1648150782.094956631]: Ignoring transform for child_frame_id "grav" from authority "unknown_publisher" because of a nan value in the transform (0.000000 0.000000 0.000000) (-nan -nan -nan nan)
    [ERROR] [1648150782.095484499]: Ignoring transform for child_frame_id "grav" from authority "unknown_publisher" because of an invalid quaternion in the transform (-nan -nan -nan nan)
             at line 244 in ~/tf2/src/buffer_core.cpp
    and repeated error message of
    [ERROR] [1648150919.088496536]: [VISLAM] ERROR CODE = 2048, Stamp: 1648150919.022946523
    I am wondering how urdf should be set. Should there be any rotations of IMU or camera in urdf file?
    urdf file I used has some rotations in y-axis for IMU and cameras.
    J DataJ J Data
    The running file is similar with this.
    <!-- camera nodelet -->
    <!-- VIO nodelet -->
    <!-- fisheye camera info spoofer -->
    <!-- imu nodelet -->
    <!-- cpa nodelet -->
    J DataJ J Data
    @Chad-Sweet
    I had a look the link you shared: snap_vio
    But I think it is not working correctly with the voxl module I have.
    Currently, I am running ROS noetic on the voxl module, and try to run the VIO with downward camer.
    By using snap_camera_ros (I edited it a little bit to use the downward camera), I can see the downward camera is correctly set up for snap_vio. Also, I can see snap_imu is working correctly, so I can see the output of imu (angular_velocity and linear_acceleration).
    But I cannot see any output of /downward/vio/odometry.
    Could you please help me to run snap_vio with the voxl module?
    What should I check first?
