    1. Home
    2. H.AL
    H
    • Profile
    • Following 0
    • Followers 0
    • Topics 3
    • Posts 5
    • Best 1
    • Controversial 0
    • Groups 0
    Posts made by H.AL
    • RE: Can someone tell me which camera is used in this video?
      @tom said in Can someone tell me which camera is used in this video?:
      Flir Boson connected over USB
      Thank you!
      posted in Image Sensors
      H
      H.AL
    • Can someone tell me which camera is used in this video?
      This video ( at minute 1:16) states that the open SDK supports thermal and low-light image sensors. Can someone tell me the exact thermal/low-light cameras used in this video, or compatible with the system?
      H
      H.AL
    • RE: Thermal Camera to VOXL2
      @Moderator said in Thermal Camera to VOXL2:
      @H-AL first you need to determine if the sensor's electrical interface is compatible. What interface exists on the sensor? Can you find an appropriate electrical connection on VOXL 2?
      Then, you need to find if there is software compatibility, does the driver current exist in ModalAI's reference code? Or, is there an implementation you can leverage for your work?
      What thermal camera do you recommend using?
      H
      H.AL
    • Thermal Camera to VOXL2
      Is it possible to link thermal optical sensors to VOXL2? Does VOXL2 support it at all?
      Thank you all.
      H
      H.AL
    • VOXL2: Adjusting bandwith of video streaming
      I assume live video streaming needs to be adjusted before we can transmit it via mobile radio? If yes how can we change the said video bandwidth?
      I would be grateful for any insight!
      H
      H.AL
