Enrico BanderaE
Enrico Bandera
@Enrico Bandera
  • kernel build
    Enrico BanderaE Enrico Bandera
    Hi all,
    I am trying to build kernel for voxl 2. So I followed instruction here: https://docs.modalai.com/voxl2-kernel-build-guide/
    All is working until sync. But when I launch the build scipts it suddenly exits wit below output:
    Any idea how to fix it?
    Thanks in advance
    Enrico
    Command output:
    [INFO] Starting Build
    [INFO] Platform: m0054
    [INFO] Build ID: lu.um.1.2.1
    [INFO] Build Type: debug
    Reversed (or previously applied) patch detected! Skipping patch.
    2 out of 2 hunks ignored
    1 out of 1 hunk ignored
    Shell environment ready to run bitake commands.
    You can now run 'bitbake <target>'
    Supported image targets are:
    qti-console-image
    qti-multimedia-image
    Run 'bitbake <pkg-name>' to build a required package, example:
    bitbake lk
    [INFO] - building kernel
    ERROR: Unable to start bitbake server (None)
    ERROR: Server log for this session (/home/user/build_mount/lu.um.1.2.1/apps_proc/build-qti-distro-ubuntu-fullstack-debug/bitbake-cookerdaemon.log):
    --- Starting bitbake server pid 2924 at 2023-09-06 12:34:50.438439 ---
    WARNING: Layer audio should set LAYERSERIES_COMPAT_audio in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti-gst should set LAYERSERIES_COMPAT_qti-gst in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti-sec should set LAYERSERIES_COMPAT_qti-sec in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer ubuntu should set LAYERSERIES_COMPAT_ubuntu in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti_display should set LAYERSERIES_COMPAT_qti_display in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti-ss-mgr should set LAYERSERIES_COMPAT_qti-ss-mgr in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer ml should set LAYERSERIES_COMPAT_ml in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti-qmmf should set LAYERSERIES_COMPAT_qti-qmmf in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti-robotics should set LAYERSERIES_COMPAT_qti-robotics in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer bt should set LAYERSERIES_COMPAT_bt in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer video should set LAYERSERIES_COMPAT_video in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti_cam should set LAYERSERIES_COMPAT_qti_cam in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer msm-data should set LAYERSERIES_COMPAT_msm-data in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti_aosphal should set LAYERSERIES_COMPAT_qti_aosphal in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer voxl2-bsp should set LAYERSERIES_COMPAT_voxl2-bsp in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer qti-adk should set LAYERSERIES_COMPAT_qti-adk in its conf/layer.conf file to list the core layer names it is compatible with.
    WARNING: Layer voxl2 should set LAYERSERIES_COMPAT_voxl2 in its conf/layer.conf file to list the core layer names it is compatible with.
    ERROR: ParseError in configuration INHERITs: Could not inherit file classes/sdllvm.bbclass
