Doug MillerD
Doug Miller
@Doug Miller
  • VOXL 2 Mini Interfacing Questions
    Doug MillerD Doug Miller
    Hello, regarding the VOXL 2 Mini:
    1. Does J9 support Host Mode yet? Goal would be to utilize J3 for a Boson sensor and utilize this port for various other devices (possible hub -> mass storage, GbE adapter, and/or USB->HDMI adapter.
    2. Do you have a cable available to use J3 as a SS interface, noting comments about missing capacitors on the Mini board and a need for a modified cable? Any guidance would be helpful, as it might present an alternative to question (1)
    3. Any general guidance for connection of J3 to a USB hub, noting past forum comments related to challenges attempting this.
    4. Recommendations to connect a small LCD display? First thought is a USB->HDMI adapter, but other suggestions or successes would be great to know.
    5. Can you confirm maximum clock rate for SPI is 50MHz?
    6. Any tricks to accessing HS UART functionality from Ubuntu environment, understanding this device is allocated to the Hexagon DSP?
