Benjamin RuksB
Benjamin Ruks
@Benjamin Ruks
  • VOXL2 px4 ESC config with QGroundControl
    Benjamin RuksB Benjamin Ruks
    @Eric-Katzfey said in VOXL2 px4 ESC config with QGroundControl:
    @Benjamin-Ruks Can you attach the output of the command journalctl -b -u voxl-px4 to show all of the output from the startup of voxl-px4?
    -- Logs begin at Thu 2023-03-02 12:58:02 UTC, end at Fri 2023-06-30 11:55:33 UTC. --
    Jun 22 16:31:59 m0054 systemd[1]: Starting px4...
    Jun 22 16:32:01 m0054 systemd[1]: Started px4.
    Jun 22 16:32:01 m0054 voxl-px4[1694]: [INFO] /etc/modalai/voxl-px4.conf not found, using defaults
    Jun 22 16:32:01 m0054 voxl-px4[1694]: Found DSP signature file
    Jun 22 16:32:01 m0054 voxl-px4[1694]: *************************
    Jun 22 16:32:01 m0054 voxl-px4[1694]: GPS=NONE
    Jun 22 16:32:01 m0054 voxl-px4[1694]: RC=SPEKTRUM
    Jun 22 16:32:01 m0054 voxl-px4[1694]: OSD=DISABLE
    Jun 22 16:32:01 m0054 voxl-px4[1694]: DAEMON_MODE=DISABLE
    Jun 22 16:32:01 m0054 voxl-px4[1694]: SENSOR_CAL=ACTUAL
    Jun 22 16:32:01 m0054 voxl-px4[1694]: EXTRA STEPS:
    Jun 22 16:32:02 m0054 voxl-px4[1694]: INFO  [px4] mlockall() enabled. PX4's virtual address space is locked into RAM.
    Jun 22 16:32:02 m0054 voxl-px4[1694]: INFO  [px4] assuming working directory is rootfs, no symlinks needed.
    Jun 22 16:32:02 m0054 voxl-px4[1694]: INFO  [muorb] Got muorb init command
    Jun 22 16:32:02 m0054 voxl-px4[1694]: Got topic data before configuration complete
    Jun 22 16:32:02 m0054 voxl-px4[1694]: *************************
    Jun 22 16:32:02 m0054 voxl-px4[1694]: GPS: NONE
    Jun 22 16:32:02 m0054 voxl-px4[1694]: RC: SPEKTRUM
    Jun 22 16:32:02 m0054 voxl-px4[1694]: OSD: DISABLE
    Jun 22 16:32:02 m0054 voxl-px4[1694]: EXTRA STEPS:
    Jun 22 16:32:02 m0054 voxl-px4[1694]: Running on M0054
    Jun 22 16:32:03 m0054 voxl-px4[1694]: INFO  [param] selected parameter default file /data/px4/param/parameters
    Jun 22 16:32:04 m0054 voxl-px4[1694]: INFO  [parameters] BSON document size 1574 bytes, decoded 1574 bytes (INT32:38, FLOAT:41)
    Jun 22 16:32:05 m0054 voxl-px4[1694]: Starting IMU driver with no rotation
    Jun 22 16:32:05 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'icm42688p start -s'
    Jun 22 16:32:05 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 10807584, local time: 10810584
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 11842132, local time: 11842794
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: muorb aggregator thread running
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] muorb protobuf initalize method succeeded
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did ADVERTISE_TEST_TYPE
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread test_MUORB
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did SUBSCRIBE_TEST_TYPE
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did TOPIC_TEST_TYPE
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] succesfully did UNSUBSCRIBE_TEST_TYPE
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] muorb test passed
    Jun 22 16:32:06 m0054 voxl-px4[1694]: ______  __   __    ___
    Jun 22 16:32:06 m0054 voxl-px4[1694]: | ___ \ \ \ / /   /   |
    Jun 22 16:32:06 m0054 voxl-px4[1694]: | |_/ /  \ V /   / /| |
    Jun 22 16:32:06 m0054 voxl-px4[1694]: |  __/   /   \  / /_| |
    Jun 22 16:32:06 m0054 voxl-px4[1694]: | |     / /^\ \ \___  |
    Jun 22 16:32:06 m0054 voxl-px4[1694]: \_|     \/   \/     |_/
    Jun 22 16:32:06 m0054 voxl-px4[1694]: px4 starting.
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [px4] startup script: /bin/sh /usr/bin/voxl-px4-start 0
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic log_message
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [parameters] Starting param sync THREAD
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Starting param sync THREAD
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: before starting the qshell_entry task
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread qshell
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell entry.....
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Init app map initialized
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: after starting the qshell_entry task
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(parameter_client_reset_response) as advertised in process_remote_topic
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic parameter_update
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_topic
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(parameter_server_set_used_request) as advertised in process_remote_topic
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_topic
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(parameter_client_set_value_response) as advertised in process_remote_topic
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [logger] logger started (mode=all)
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: icm42688p start -s
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'icm42688p'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = '-s'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_accel
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_gyro
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: ICM42688P::probe successful!
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: on SPI bus 1
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: >>> ICM42688P this: 3176a170
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: icm42688p start -s
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic qshell_retval
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Register interrupt b21d2fd8 e620e69c 3176a170
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_gyro_fifo
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_accel_fifo
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic imu_server
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'icp101xx'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = '-I'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg3 = '-b'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg4 = '5'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: icp101xx #0 on I2C bus 5
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:  address 0x63
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: modal_io staINFO  [qshell] Send cmd: 'modal_io start'
    Jun 22 16:32:06 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 11942515, local time: 11944227
    Jun 22 16:32:07 m0054 voxl-px4[1694]: Starting Spektrum RC
    Jun 22 16:32:07 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'spektrum_rc start'
    Jun 22 16:32:07 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 12975221, local time: 12976016
    Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'voxlpm start -X -b 2'
    Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14012890, local time: 14013491
    Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'sensors start'
    Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14131660, local time: 14133694
    Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'ekf2 start'
    Jun 22 16:32:08 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14424847, local time: 14427135
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_pos_control start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14566613, local time: 14567757
    Jun 22 16:32:09 m0054 voxl-px4[1694]: rt
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'modal_io'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_outputs
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: modal_io start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Opened UART ESC device
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic esc_status
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_baro
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: spektrum_rc start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'spektrum_rc'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread spektrum_rc_main
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_spektrum_rc_main with tid 2097647
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: spektrum_rc start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: voxlpm start -X -b 2
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'voxlpm'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = '-X'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg3 = '-b'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg4 = '2'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: *** I2C Device ID 0xd24411 13779985
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Set i2c address 0x6a, fd 1
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Set i2c address 0x44, fd 1
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic battery_status
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: voxlpm #0 on I2C bus 2
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:  (external)
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:  address 0x44
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: voxlpm start -X -b 2
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic power_monitor
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: sensors start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'sensors'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_selection
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensors_status_imu
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_acceleration
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_angular_velocity
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensor_combined
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_air_data
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_gps_position
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_imu
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_imu_status
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: sensors start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: ekf2 start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'ekf2'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic sensors_status_baro
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_attitude
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_local_position
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_event_flags
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_innovation_test_ratios
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_innovation_variances
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_innovations
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_sensor_bias
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_states
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_status_flags
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: ekf2 start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic ekf2_timestamps
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_odometry
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_baro_hgt
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_pos
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_fake_hgt
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_gravity
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_pos_control start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_pos_control'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic takeoff_status
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_pos_control start
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_att_contINFO  [qshell] Send cmd: 'mc_att_control start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14621967, local time: 14624142
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_rate_control start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14736644, local time: 14738248
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_hover_thrust_estimator start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14786154, local time: 14787537
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'mc_autotune_attitude_control start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14829945, local time: 14831904
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'land_detector start multicopter'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14883595, local time: 14885803
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'manual_control start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 14945246, local time: 14948051
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'control_allocator start'
    Jun 22 16:32:09 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15219636, local time: 15220809
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'rc_update start'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15478931, local time: 15481033
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'commander start'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15718620, local time: 15720616
    Jun 22 16:32:10 m0054 voxl-px4[1694]: rol start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_att_control'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_att_control start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_rate_control start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_rate_control'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic rate_ctrl_status
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_rate_control start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_hover_thrust_estimator start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_hover_thrust_estimator'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_hover_thrust_estimator start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: mc_autotune_attitude_control start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'mc_autotune_attitude_control'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic autotune_attitude_control_status
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: mc_autotune_attitude_control start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: land_detector start multicopter
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'land_detector'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = 'multicopter'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: land_detector start multicopter
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_land_detected
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: manual_control start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'manual_control'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: manual_control start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic manual_control_setpoint
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: control_allocator start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'control_allocator'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic control_allocator_status
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(control_allocator_status) as advertised in process_remote_topic
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_motors
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_servos
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_servos_trim
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: control_allocator start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: rc_update start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'rc_update'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: rc_update start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: commander start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'commander'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Creating pthread commander
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Successfully created px4 task PX4_commander with tid 2097643
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic led_control
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: LED: open /dev/led0 failed (22)
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic tune_control
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: commander start
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic event
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic health_report
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic failsafe_flags
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_armed
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_control_mode
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_thrust_setpoint
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_torque_setpoint
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_status
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic failure_detector_status
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_rates_setpoint
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_local_posINFO  [qshell] Send cmd: 'commander mode manual'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15753909, local time: 15755266
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'param_set_selector start'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15788509, local time: 15790356
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] Send cmd: 'flight_mode_manager start'
    Jun 22 16:32:10 m0054 voxl-px4[1694]: INFO  [qshell] qshell return value timestamp: 15961043, local time: 15962774
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] MAVLink only on localhost (set param MAV_{i}_BROADCAST = 1 to enable network)
    Jun 22 16:32:12 m0054 voxl-px4[1694]: ition_setpoint
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_attitude_setpoint
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: commander mode manual
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'commander'
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'mode'
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg2 = 'manual'
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_command
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: commander mode manual
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic vehicle_command_ack
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(vehicle_attitude_setpoint) as advertised in process_remote_topic
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: param_set_selector start
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'param_set_selector'
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg1 = 'start'
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: param_set_selector start
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: qshell gotten: flight_mode_manager start
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI:   arg0 = 'flight_mode_manager'
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Marking DeviceNode(vehicle_command) as advertised in process_remote_topic
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Ok executing command: flight_mode_manager start
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic actuator_controls_status_0
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [dataman] data manager file '/data/px4/dataman' size is 7866640 bytes
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic transponder_report
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic rtl_time_estimate
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic position_setpoint_triplet
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] mode: Onboard, data rate: 100000 B/s on udp port 14556 remote port 14557
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic telemetry_status
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] partner IP: 127.0.0.1
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic vehicle_visual_odometry
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic offboard_control_mode
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic obstacle_distance
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Advertising remote topic timesync_status
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_hgt
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_pos
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_vel
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic estimator_aid_src_ev_yaw
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [mavlink] mode: Normal, data rate: 100000 B/s on udp port 14558 remote port 14559
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [muorb] SLPI: Marking DeviceNode(telemetry_status) as advertised in process_remote_topic
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic mavlink_log
    Jun 22 16:32:12 m0054 voxl-px4[1694]: ERROR [muorb] SLPI: Preflight Fail: low battery
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [uORB] Advertising remote topic home_position
    Jun 22 16:32:12 m0054 voxl-px4[1694]: INFO  [px4] Startup script returned successfully
    Jun 22 16:32:12 m0054 voxl-px4[1694]: [48.0K blob data]
    @Eric-Katzfey The Receiver is working fine. QGroundControl tells me that no magnetometer is attached (also no gps module). So I had to turn both of in order to be able to arm the drone. As I mentioned above I flashed the newes System image and since than there is no life signal from the gps/mag module.
    By reading this post I noticed that the file /etc/modalai/voxl-px4.config does not exist on my VOXL2. Maybe that's the reason? Also I tried px4-qshell gps start but nothing changed.
    @Eric-Katzfey I am using "VOXL 2 GPS / Magnetometer / RC / Bind Module w/ Receiver" Bundle (MDK-M0094-2-02)
  • Heating and Excessive CPU usage in VOXL 2 under normal operation
    @Jyotish-Kumar Same Issues here. Running camera server with 4 tracking cams and px4 flight stack with mavlink server and reaching over 90 Degree CPU temp.
    @Eric-Katzfey Thank you for your quick reply. I flashed the latest platform release and also build and installed PX4-1.14. Now everything works fine for the ESC and Motor Part.
    However, I think I may have missed some crucial setup steps, since the GPS Module is not working anymore (The LED does not even light up). Any quick suggestions on what I could have missed? (Worked fine before the flashing)
    I am currently having issues following the docs for using the VOXL ESC with PX4.
    QGroundControl is not showing the "Actuators" tab but a "Motors" tab instead and i am not able to assign motor position and actuator outputs. Therefore i am not able to arm my vehicle or spin the motors with the given sliders.
    Also I am missing the mentioned MODAL_IO parameters. The Documentation states, that on older voxl-px4 versions (i am currently using 1.12.31) instead of "MODAL_IO" the paramters are named "UART_ESC". Here ist the output of my parameter list:
    voxl2:~$ px4-param show | grep UART
    x   UART_ESC_BAUD [596,1580] : 250000
    x + UART_ESC_CONFIG [597,1581] : 1
    x   UART_ESC_MODE [598,1582] : 0
    x   UART_ESC_MOTOR1 [599,1583] : 3
    x   UART_ESC_MOTOR2 [600,1584] : 2
    x   UART_ESC_MOTOR3 [601,1585] : 4
    x   UART_ESC_MOTOR4 [602,1586] : 1
    x   UART_ESC_RPM_MAX [603,1587] : 15000
    x   UART_ESC_RPM_MIN [604,1588] : 5500
    x   UART_ESC_T_COSP [605,1589] : 0.9900
    x   UART_ESC_T_DEAD [606,1590] : 20
    x   UART_ESC_T_EXPO [607,1591] : 35
    x   UART_ESC_T_MINF [608,1592] : 0.1500
    x   UART_ESC_T_PERC [609,1593] : 90
    x   UART_ESC_VLOG [610,1595] : 0
    I am using the VOXL ESC 4-in-1 Digital I/O UART in combination with a VOXL2 Board.
    I can spin the motors with the following command
    px4-qshell modalai_esc -i 1 -r 1000 rpm
    but not with the sliders in QGroundControl.
    What am I missing? Are you recommending to update the package?
