Anton GerelesA
Anton Gereles
@Anton Gereles
  • Should I upgrade?
    Anton GerelesA Anton Gereles
    @Eric-Katzfey so why i bought VOXL Flight Deck month ago with 3.3.0-0.5.0 version? it was difficult for your team to upgrade to new version before sending? wonderful service for 1000$. im 2 weeks trying to get video streaming to qgc. Result - 0.
  • VIO coordinates suddenly resets to 0,0,0 in the air!!! every flight
    @Chad-Sweet
    maybe I should try to fly without gps from the beginning? with a mask value of 280. do I need to include ev_rotate? and in that case I'd like to use the barometer for the altitude, not the VIO. I think for high altitudes it will be more accurate. how to do it?
    Do you think it is possible to fly using VIO at 500 meters altitude and at a distance of 10-15 km? somewhere on this forum someone said that there are no height restrictions.
    Feature Requests
    @Chad-Sweet and also i found this
    https://docs.px4.io/main/en/advanced_config/tuning_the_ecl_ekf.html#external-vision-system
    what do you think?
    Feature Requests
    @Chad-Sweet what do you think?
    Feature Requests
    sometimes I watch qvio. I understand only xyz. what means other parameters Q, PTS, EX, GAIN?
    my problem very similar to this https://forum.modalai.com/topic/1129/ekf2_aid-flying-without-gps
    maybe there is some solution? we need to fly far and high with gps, but sometimes the gps signal is lost and we would like to use the VIO at these moments. help us please.
    Feature Requests
    I bought VOXL Flight Deck. Every flight I have a crash. Great $1000 product with zero support! While flying outside using GPS and VIO (aid_mask value 329) suddenly VIO position values become 0.0.0, the drone goes out of control and crashes. Maybe someone knows what is the reason?
    Feature Requests
  • VOXL Flight Deck - crash on every flight!! need help
    the situation is: I bought a voxl to fly my drone outside in places where sometimes there is no gps signal. i.e., I start the flight with gps, then the gps signal disappears and I have to continue the flight or return using the VIO. every time everything starts fine, but at some point the drone loses position and goes into altitude mode. this happens both with and without a running gps. If I turn off the gps and use only VIO, then at some point the x y values ​​​​change sharply and the drone crashes or goes into altitude mode. what should I do? I fly with a ekf2_aid_mask 329. I need to urgently solve this problem.
  • Fly outside with/without GPS using VOXL flight deck
    I bought VOXL flight deck. Set it on my drone. What next? Changed ekf2_aid_mask. Something else? I need to fly outside using GPS, but sometimes there are no GPS signal and I want to use vio. Can someone help me please?
  • how to use VOXL flight deck
    hi all. I have absolutely no understanding of such high technology, but I bought a voxl flight deck and I need to install it on my drone. I installed it, everything connected. what's next? How can I fly outdoors if there is no gps? in addition to the fact that I have to set up the flight controller as usual, such as pids and everything else. I need to customize the ekf2_aid_mask. anything else to do? how to run voxl or does it start itself? all I did was build the drone, tune the pid and change the ekf2_aid_mask values. but the system is not working well. I dont understand it works or not.
  • Weather restrictions
    What is the temperature for use? I flew at +5 Celsius - big problems with flight stability. Also interested in the issue of lighting. It was dusk and the drone began to fly inadequately.
