No connection to QGroundControl after upgrading to dev channel
Worked before the upgrade from stable to dev but.
The voxl-vision-px4 service emits:Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_insert_pc, ringbuf uninitialized Jan 01 00:04:08 apq8096 voxl-vision-px4[1954]: ERROR in obs_pc_ringbuf_cleanup_old, ringbuf uninitialized -
Hello, do you mind sharing the contents of the config file /etc/modalai/voxl-vision-px4.conf and the output from voxl-vision-px4 when started from a terminal? I'd like to see what it prints before getting to the ringbuf error. Thank you!
James
I was able to fix the ringbuffer error by running the voxl-configure-vision-px4 after the update.
However there still is no connection to QGroundControl. Runningtcpdump udp port 14550 -vvhints that the voxl-vision-px4 server is not sending packets (consistent with the lack of output with--debug_udp_send) ./** * VOXL Vision PX4 Configuration File * */ { "qgc_ip": "192.168.8.89", "en_localhost_mavlink_udp": true, "en_secondary_qgc": false, "secondary_qgc_ip": "192.168.2.1", "qgc_udp_port_number": 14550, "localhost_udp_port_number": 14551, "udp_mtu": 512, "en_vio": true, "en_voa": true, "en_send_vio_to_qgc": false, "en_send_voa_to_qgc": false, "en_set_clock_from_gps": true, "en_force_onboard_mav1_mode": true, "en_reset_px4_on_error": true, "qvio_auto_reset_quality": 0.00050000002374872565, "horizon_cal_tolerance": 0.300000011920929, "voa_upper_bound_m": -0.15000000596046448, "voa_lower_bound_m": 0.15000000596046448, "offboard_mode": "off", "follow_tag_id": 0, "figure_eight_move_home": true, "en_tag_fixed_frame": false, "fixed_frame_filter_len": 5, "en_transform_mavlink_pos_setpoints_from_fixed_frame": false }loading our own config file ================================================================= Parameters as loaded from config file: qgc_ip: 192.168.8.89 en_localhost_mavlink_udp 1 en_secondary_qgc: 0 secondary_qgc_ip: 192.168.2.1 qgc_udp_port_number: 14550 localhost_udp_port_number: 14551 udp_mtu: 512 en_vio: 1 en_voa: 1 en_send_vio_to_qgc: 0 en_send_voa_to_qgc: 0 en_set_clock_from_gps: 1 en_force_onboard_mav1_mode: 1 en_reset_px4_on_error: 1 qvio_auto_reset_quality: 0.000500 horizon_cal_tolerance: 0.300000 voa_upper_bound_m: -0.150000 voa_lower_bound_m: 0.150000 offboard_mode: off follow_tag_id: 0 figure_eight_move_home: 1 en_tag_fixed_frame: 0 fixed_frame_filter_len: 5 en_transform_mavlink_pos_setpoints_from_fixed_frame:0 ================================================================= loading extrinsics config file starting geometry module starting px4 monitor starting px4 mavlink starting udp mavlink Adding manual QGC IP address to udp connection list: 192.168.8.89 Added new UDP connection to 192.168.8.89 starting px4 shell starting fixed pose input starting vio manager starting tag manager starting voa manager starting control input pipe Init complete, entering main loop Connected to TOF Connected to voxl-qvio-server updating to use imu: imu1 done updating transforms to use imu: imu1Enabling
en_send_vio_to_qgcoren_send_voa_to_qgcwill send udp packets which show up in QGroundControl MAVLink Inspector (but still no proper connection) -
en_send_vio_to_qgcoren_send_voa_to_qgcwill send udp packets which show up in QGroundControl MAVLink Inspector (but still no proper connection)@jlinnpmd can you drop which services are running with ‘voxl-inspect-services —version’?
I had a similar issue upgrading to dev channel recently as well and something between the ‘voxl-mavlink-server’ and ‘voxl-vision-PX4’ wasn’t right until I reinstalled/installed the mavlink server.
I also added an additional opkg dev channel for VOXL1 may be http://voxl-packages.modalai.com/dists/apq8096/dev/binary-arm64/ based on where builds out of gitlab CI are getting dropped. Seemed like quite a few dependencies are missing from the dev channel listed in docs at this time and this had newer dependencies as required by the latest voxl-suite.
Take my advice with a grain of salt… the Modal team probably has a better answer but both above fixed my QGC connectivity issues without having to build things myself.
