  3. Battery setup
Battery setup
flight-deck
3 Posts 2 Posters 749 Views 1 Watching
  • Zeev MindaliZ Offline
    Zeev Mindali
    Dear all,
    I have 6 cell / 22.8v 4500 mah battery.
    Can i use then or strictly 4s batteries?
      What are you connecting your battery to? If it's ModalAI's APMv3, then the datasheet can be found here
      From the datasheet:
      LIPO range 2S-6S [2 cell (6.4V min, 7.4V nom, 8.4V max) 6 cell ( 19.2V min, 22.2V nom, 25.2V max)]
      Note: Absolute max voltage of design is limited to 28V due to the INA231 current sense IC’s.
        Zeev Mindali
        sweet,
        i connecting to modalai voxl flight deck,
        i receiving it today, just wanted to be sure that i connecting the correct battery.
        already add support for java, rest (with java spring), python and js/node.js.
        changed also the web server to react with easy access.
        i will share with you my code 🙂 (basicly a docker on same network)
