  3. java support and examples
flight-deck
4 Posts 3 Posters 805 Views 2 Watching
  • Zeev MindaliZ Offline
    Zeev Mindali
    dear all,
    where I before purchase the voxl flight deck with camera for testing.
    I looking for a solution for a major project that I need.
    where I can find some examples written in java.
    the main goal is to use it on android based machine
    or with web application, using java spring and react.
    thanks in advance
    zeev.
      Hi Zeev,
      We have no Java based references at this time. We have a pretty easy to use interface (basically, you can read from files, named pipes to be more exact).
      Here's some ideas:
      https://docs.modalai.com/mpa-services/
      Say you want to get IMU data? Ready from a file:
      https://docs.modalai.com/voxl-imu-server/#output-type
      /run/mpa/imu0 and /run/mpa/imu1
      Where the interface, for this data type, looks like:
      typedef struct imu_data_t{
      	uint32_t magic_number;  ///< Set to IMU_IMAGE_MAGIC_NUMBER for frame syncing
      	float accl_ms2[3];      ///< XYZ acceleration in m/s^2
      	float gyro_rad[3];      ///< XYZ gyro rotation in rad/s
      	float temp_c;           ///< temp in C, IMU_INVALID_TEMPERATURE_VALUE if no thermometer present
      	uint64_t timestamp_ns;  ///< timestamp in nanoseconds, uses system clock_monotonic
      } __attribute__((packed)) imu_data_t;
        Zeev Mindali
        Hi modaltb,
        I have written MAVLink commands interface for java (working on ap and px4)
        is there a way in your system (with or without MAVLink commands) to tell the drone move 2m left , 2m up, and so on?
        if it have, I can put a purchase for one development kit for testing and development and then to a large number of it.
          There is MAVROS and MAVSDK which might help with what you are looking for
          https://docs.modalai.com/mavros
          https://docs.modalai.com/mavsdk
