  3. Replacement motors for m500
2 Posts 2 Posters 643 Views
  • Todd HumphreysT Offline
    Todd Humphreys
    It appears that Holybro no longer sells the 2216 880KV motors used on the m500. Any suggestions for replacement motors?
    • Jeremy SchmidtJ Offline
      Jeremy Schmidt
      wrote on last edited by Jeremy Schmidt
      @Todd-Humphreys
      Hi Todd,
      I believe they are replacing them with almost identical motors but with a slightly higher KV value. If you can source those then they would be a drop in replacement.
      If you're interested in something else, then here's some that I've tested before. The only thing is you'd need to solder the 3 male 2mm bullet connectors onto each motor. Otherwise they're drop in replacements.
      https://usa.banggood.com/Racerstar-Racing-Edition-2216-BR2216-810KV-2-4S-Brushless-Motor-For-350-380-400-450-RC-Drone-FPV-Racing-p-1083206.html?utm_source=googleshopping&utm_medium=cpc_organic&gmcCountry=US&utm_content=minha&utm_campaign=minha-usg-pc&currency=USD&cur_warehouse=CN&createTmp=1&ID=521309&utm_source=googleshopping&utm_medium=cpc_bgcs&utm_content=sandra&utm_campaign=sandra-SSC-usg-sku-1019-xp-cvrcart-11sale-21&ad_id=554267045258&gclid=CjwKCAiAjoeRBhAJEiwAYY3nDF7t6brTndAN6m0qocX3YTDihgCK1dw6y2-u2YtW9OWuC_Xq_bipZxoCnv8QAvD_BwE
