  2. VOXL SDK and Software
  3. Voxl-IO questions (GPIO & i2c)
3 Posts 3 Posters 888 Views 2 Watching
  • A Offline
    amitmol
    I have a few questions about the voxl-io library, and I would love if you could help me:
    1.1. Missing ability to GPIO interrupt (or missing documentation?)
    1.2. Missing ability to control of Pull Up/Down (Is the hardware exist to do so?, or missing documentation?)
    1.3. Need clarification in the i2c api, can I write to a device without specifying a designated register?
    	For example in the smbus linux library: (https://www.kernel.org/doc/html/latest/i2c/smbus-protocol.html)
    		i2c_smbus_write_byte(...): Writes a single byte to a device
    		i2c_smbus_write_byte_data(...): Writes a single byte to a designated register on the device
      Hi @amitmol ,
      The VOXL is based on the snapdragon 820, built for smart phones, and has a bit less control than a microcontroller with configurability....
      • Interrupt- not out of the box as far as I know
      • pull up/down - this is a device tree modification likely, not something quick
      • on this platform, we use voxl-io to send/receive the I2C commands to the sDSP, so it's what's exposed there presently only unless it's added later
        We have example Python code in voxl-modem to control the B2B GPIO
        ## All GPIO pins need to be exported before they can be used
        def gpio_export(num):
            subprocess.call("echo " + num + " > /sys/class/gpio/export",
                            stderr=FNULL, shell=True)
        ## Each GPIO has to have its direction set prior to use
        # @param num  pin number
        # @param direction 'in' or 'out'
        def gpio_direction_map(num, direction):
            subprocess.call("echo " + direction + " > /sys/class/gpio/gpio" \
                            + num + "/direction",
        ## Set a value to an 'out' gpio
        def set_gpio(num, value):
            subprocess.call("echo " + value + " > /sys/class/gpio/gpio" + num + "/value",
        ##  Reads a GPIO pin
        #   @apram pin
        #       pin number
        #   @return
        #       integer value [0,1]
        def gpio_read_int(pin_int):
            gpio_file = '/sys/class/gpio/gpio' + str(pin_int) + '/value'
            value = subprocess.check_output(['cat', gpio_file]).strip()
            return int(value)
