  2. VOXL Compute & Autopilot
  3. VOXL
  4. Persistent Log Storage
Scheduled Pinned Locked Moved VOXL
6 Posts 1 Posters 996 Views
  • wilkinsafW Offline
    wilkinsafW Offline
    wilkinsaf
    wrote on last edited by wilkinsaf
    I am looking to have journald logs persist.
    I understand that journald stores logs under /var/log/journal
    However, I can see that /var/log/ is under volatile storage.
    I understand that I should be logging to /data if I would like things to persist. Is there a configuration that ModalAI recommends to log service file output on VOXL?
      wilkinsafW Offline
      wilkinsaf
      I might end up having to specify specific log files to write to in my .service files per
      https://www.freedesktop.org/software/systemd/man/systemd.exec.html#StandardOutput=
        wilkinsafW Offline
        wilkinsaf
        Was going to use syslog, but saw that the service file points to null. Was wondering if this is done on purpose?
          wilkinsafW Offline
          wilkinsaf
          Thinking an easier way here is to just change the symbolic link here
          and then modify journald config file to make sure we do not fill up storage with logs
            wilkinsafW Offline
            wilkinsaf
            This seems to work, but not from bootup.
            Usually, the systemd-journal-flush.service watches for /var/log/journal to be mounted and then switches logging over to that folder, but that does not seem to be happening.
            Instead, I have to restart the systemd-journald.service to get it to log in the correct spot.
            Maybe because it is a symbolic link, and that is why the service does not see it mounted.... going to try and test that theory
              wilkinsafW Offline
              wilkinsaf
              Yeah, all systemd-journal-flush.service is doing is running journalctl --flush which is not doing anything when run manually
