    rodep ssl error
    • A
      abdullah.sorathi
      I am not able to init rosdep. When I do sudo rosdep init it keeps giving error
      ERROR: cannot download default sources list from:
      https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/sources.list.d/20-default.list
      Website may be down.
      I tried manually downloading 20-default.lit using wget and placing it inside /etc/ros/rosdep/sources.list.d/ directory and tried running rosdep update still it says connection timeout whereas these url are perfectly working when open through browser
      yocto:/etc/ros/rosdep/sources.list.d# rosdep update
      reading in sources list data from /etc/ros/rosdep/sources.list.d
      Warning: running 'rosdep update' as root is not recommended.
        You should run 'sudo rosdep fix-permissions' and invoke 'rosdep update' again without sudo.
      ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/osx-homebrew.yaml]:
      	<urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/osx-homebrew.yaml)
      ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/base.yaml]:
      	<urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/base.yaml)
      ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/python.yaml]:
      	<urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/python.yaml)
      ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/ruby.yaml]:
      	<urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/rosdep/ruby.yaml)
      ERROR: unable to process source [https://raw.githubusercontent.com/ros/rosdistro/master/releases/fuerte.yaml]:
      	Failed to download target platform data for gbpdistro:
      Query rosdistro index https://raw.githubusercontent.com/ros/rosdistro/master/index.yaml
      ERROR: error loading sources list:
      	<urlopen error <urlopen error [Errno 110] Connection timed out> (https://raw.githubusercontent.com/ros/rosdistro/master/index.yaml)>
      I tried doing this updating certificates but it didn't work
      update-ca-certificates
      cp /etc/ssl/certs/ca-certificates.crt /usr/lib/ssl/certs
      I am using voxl-flightdeck and these are the versions of onboard images
      system-image:    ModalAI 2.5.2 BUILDER: ekatzfey BUILD_TIME: 2020-08-24_00:08
      kernel:          #1 SMP PREEMPT Wed Sep 9 22:28:09 UTC 2020 3.18.71-perf
      factory-bundle:  1.0.1
      architecture:    aarch64
      processor:       apq8096
      os:              GNU/Linux
      voxl-suite:
      Package: voxl-suite
      Version: 0.2.0
      Depends: docker, imu_app (= 0.0.6), libvoxl_io (= 0.5.2), voxl-cam-manager (= 0.2.2), voxl-docker-support (= 1.1.1), voxl-hal3-tof-cam-ros (= 0.0.2), voxl-modem (= 0.10.0), voxl-nodes (= 0.0.8), voxl-rtsp (= 1.0.2), voxl-utils (= 0.5.2), voxl-vision-px4 (= 0.6.8), voxl_imu (= 0.0.4), voxl-time-sync (= 0.0.1), voxl-vpn (= 0.0.2), librc_math (= 1.1.2), libmodal_pipe (= 1.2.2), modalai-vl (= 0.1.3)
      Section: base
      Architecture: armv7a
      Maintainer: james@modalai.com
      MD5Sum: af706cd3c1ea59f274f2ed9b93141f1d
      Filename: voxl-suite_0.2.0.ipk
      Description: meta-package to install all of the voxl-suite
      Installed-Time: 4024
      • A
        abdullah.sorathi
        I am able to get rosdep working by updating ca-certificates through this
        and setting SSL_CERT_FILE variable to point to ca-certificate path
        export SSL_CERT_FILE=/usr/lib/ssl/certs/ca-certificates.crt
        but now rosdep dos not detect OS used by Voxl
        ERROR: Rosdep experienced an error: Could not detect OS, tried ['windows', 'ubuntu', 'slackware', 'rhel', 'qnx', 'osx', 'opensuse', 'opensuse', 'mint', 'linaro', 'gentoo', 'funtoo', 'freebsd', 'fedora', 'elementary', 'debian', 'cygwin', 'centos', 'arch']
        • Chad SweetC
          Chad Sweet ModalAI Team
          Thanks for posting the ssl fix. We're looking into this. We don't typically use rosdep for anything. Is there something specific you need to get working?
          A more traditional ROS experience is easy to achieve running Ubuntu in a Docker on VOXL : https://docs.modalai.com/docker-on-voxl/
          • A
            abdullah.sorathi
            I was trying to rosdep update on some custom packages. But then ended up adding source directly to the workspace.
