  3. setting up voxl-portal
2 Posts 2 Posters 716 Views 1 Watching
  • Steve AriasS Offline
    Steve Arias
    wrote on last edited by Steve Arias
    I have VOXL Flight and I just finished the VOXL Quickstart documentation. It is in station mode and is connected to a working network. I have enabled voxl-camera-server, voxl-cpu-monitor, voxl-imu-server, voxl-qvio-server, voxl-tflite-server and voxl-vision-px4 using voxl-configure-mpa --wizard. I ran opkg update and opkg install voxl-portal which installed voxl-portal. I then ran adb shell voxl-portal which gave me the following output: 2022-01-09 20:36:54 2 mongoose.c:3317:mg_listen 1 accepting on http://0.0.0.0:80 (port 80). What is the next step to see the portal?
      @Steve-Arias,
      Once you have voxl-portal started either via the command line or as a service, you can access the webserver on a device within the same network just by navigating to your voxl's IP address.
