  3. VOXL CPU Performance with ROS
voxl
3 Posts 2 Posters 809 Views 2 Watching
  • NirgeN Offline
    NirgeN Offline
    Nirge
    I'm migrating an app to VOXL, and noticed the performance is better, but the hidden "sys" values are negating any advantage (28% when 21% is for system).
    Mem: 2737440K used, 1123880K free, 41796K shrd, 140144K buff, 1824000K cached
    CPU:  6.9% usr 20.9% sys  0.0% nic 67.4% idle  0.0% io  2.3% irq  2.3% sirq
    Load average: 3.84 3.14 1.65 4/750 13545
    Using dmesg it seems it's overflowing with errors:
    [  586.199252] type=1123 audit(1641721335.544:9489): pid=15875 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0-s15:c0.c1023 msg='cwd="/root/.ros" cmd=69776C69737420776C616E30207363616E terminal=? res=failed'
    [  586.229739] type=1123 audit(1641721335.574:9490): pid=15876 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0-s15:c0.c1023 msg='cwd="/root/.ros" cmd=69776C69737420776C616E30207363616E terminal=? res=failed'
    [  586.269861] type=1123 audit(1641721335.614:9491): pid=15877 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0-s15:c0.c1023 msg='cwd="/root/.ros" cmd=69776C69737420776C616E30207363616E terminal=? res=failed'
    [  586.304811] type=1123 audit(1641721335.644:9492): pid=15878 uid=0 auid=4294967295 ses=4294967295 subj=system_u:system_r:init_t:s0-s15:c0.c1023 msg='cwd="/root/.ros" cmd=69776C69737420776C616E30207363616E terminal=? res=failed'
    [  586.505185] audit: audit_lost=900 audit_rate_limit=20 audit_backlog_limit=64
    [  586.505199] audit: rate limit exceeded
    Any suggestions on how to diagnose this issue?
      If you are just using top, it may not be the complete story. The Snapdragon 821 CPU scales the frequencies based on usage, but top does not take that into account.
      The voxl-inspect-cpu tool does take that into account
      The thermal and performance page may also be interesting
      NirgeN 1 Reply Last reply
      • Chad SweetC Chad Sweet
        NirgeN Offline
        NirgeN Offline
        Nirge
        @Chad-Sweet Hi, the utility shows the same CPU usage if I add usr & sys.
