  3. voxl-tflite-server crashes after 5-10 minutes
voxl
7 Posts 4 Posters 2.5k Views 1 Watching
  • C Offline
    C Offline
    colerose
    After running:
    roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch
    on the VOXL with the latest stable version of voxl-tflite-server running (v0.1.6), I noticed that the tflite pipe would disconnect and reconnect after about 5-10 minutes.
    Here is an output of that occuring:
    Found new interface: tflite
    Found new interface: tracking
    Found new interface: cpu_monitor
    Found new interface: imu0
    Found new interface: imu1
    Found new interface: vvpx4_gps_raw_int
    Found new interface: vvpx4_mavlink_io
    Found new interface: vvpx4_sys_status
    Found new interface: vvpx4_vehicle_gps
    Found new interface: vvpx4_body_wrt_fixed
    Found new interface: vvpx4_body_wrt_local
    Found new interface: qvio_extended
    Found new interface: vvpx4_shell
    Interface: tflite's data pipe disconnected, closing until it returns
    Found pipe for interface: tflite, now advertising
    When this happens all of the cameras on voxl-portal are no longer viewable. I can select them but no image shows up. Even if I restart voxl-portal or the voxl-tflite server the cameras don't show up in voxl-portal. The only fix to this is to restart the voxl entirely.
    I then tested to see if this happened without voxl-mpa-to-ros running. Unfortunately, the same error still occurs. After about 5-10 minutes the cameras are no longer viewable in voxl-portal with the only fix being to reboot the voxl.
      @colerose please see the latest version v0.1.8 on dev or stable. This version also includes a new output pipe (tflite_data) by default that will publish metadata about detections, in the form of:
      typedef struct object_detection_msg {
          int64_t timestamp_ns;
          uint32_t class_id;
          char class_name[64];
          float class_confidence;
          float detection_confidence;
          float x_min;
          float y_min;
          float x_max;
          float y_max;
      } __attribute__((packed)) object_detection_msg;
      typedef struct detections_array {
          int32_t num_detections;
          object_detection_msg detections[64];
      } __attribute__((packed)) detections_array;
      • C Offline
        C Offline
        colerose
        @Matt-Turi thanks for letting me know! Does this new version crash less often? Also, will the output pipe work with voxl_mpa_to_ros?
          @colerose Yes, the new version fixes this issue and should no longer be a problem.
          The new output pipe is not compatible with voxl_mpa_to_ros yet, but it will be added in very soon!
          W 1 Reply Last reply
          • ? A Former User
            W Offline
            W Offline
            Wei Cui
            @Matt-Turi Can you please let us know if voxl_mpa_to_ros is compatible with the new output pipe? Thanks.
              @Wei-Cui @colerose The dev latest version of voxl_mpa_to_ros is now compatible with the new output pipe. See the latest package on our opkg repo titled voxl-nodes_0.2.2_202112212238.ipk or public gitlab.
              • H Offline
                H Offline
                hedd
                hello @colerose how do u get all these topics by launching just roslaunch voxl_mpa_to_ros voxl_mpa_to_ros.launch because when i launch it i get just these topics :
                MPA to ROS app is now running
                Found new interface: hires
                Found new interface: qvio_overlay
                Found new interface: stereo
                Found new interface: voa_pc_out
                Thank u in advance for your reply
