  3. Only 2 out of 4 cameras are detected
2 Posts 2 Posters 275 Views
  • P Offline
    P Offline
    Piyush Singh
    wrote on last edited by Piyush Singh
    Hello ModalAI Team,
    I am working on an indoor drone using VOXL2 Mini, and I would appreciate your guidance regarding a camera detection issue with a multi-sensor setup.
    Goal
    My goal is to build an indoor drone, primarily relying on visual sensing rather than GPS.
    Camera Modules Used
    • M0169 – PMD ToF
    • M0014 – Tracking Camera
    • M0024 – High-Resolution Camera
    Hardware Connections
    • J6 → M0084
      • JU: PMD-ToF (external 5V power supplied to M0169)
      • JL: High-Resolution Camera
    • J7 → M0135
      • JU: Tracking Camera
      • JL: Tracking Camera
    Observed Issue
    When using a custom camera configuration file, "voxl-camera-server" detects only 2 out of 4 cameras:
    • Detected: High-Resolution + Tracking (Down)
    • Not detected: PMD-ToF + Tracking (Second unit)
    Debug Information
    While debugging, I consistently get the following error:
    ToF resolution not supported (224 × 1557)
    And Tracking front is not detected.
    To address this, I manually modified "/etc/modalai/voxl-camera-server.conf":
    • "preview_width": 240
    • "preview_height": 180
    After restarting "voxl-camera-server", the error still persists(Resolution error), and only 2 cameras are detected.
    My Questions
    1. From an indoor drone perspective, is my approach of using 4 camera sensors (ToF + dual tracking + high-resolution) correct, or would you recommend a different sensor combination?
    2. Why are only 2 cameras detected despite all 4 being connected correctly?
    3. Why does the ToF camera still report an unsupported resolution (224 × 1557) even after manually setting the preview resolution?
    4. Is there any additional configuration required for PMD-ToF when used alongside multiple cameras on VOXL2 Mini?
    Any guidance, recommended configuration, or known limitations would be very helpful.
    ModeratorM 1 Reply Last reply
    • P Piyush Singh
      Hello ModalAI Team,
      Goal
      Camera Modules Used
      • M0169 – PMD ToF
      • J6 → M0084
      • J7 → M0135
      Observed Issue
      Debug Information
      My Questions
      @Piyush-Singh Have you tried voxl-camera-server -d0 found here https://docs.modalai.com/voxl-camera-server/#troubleshooting ?
      You cannot plug in cameras arbitrarily, you'll need to use one of the supported camera configurations: https://docs.modalai.com/voxl2-camera-configs/
