  3. Cant use Mavsdk! please Help!
6 Posts 2 Posters 973 Views 1 Watching
  • Daniel RinconD Offline
    Daniel Rincon
    wrote on last edited by Daniel Rincon
    when I use the mavsdk-docker example it just stays here:
    voxl2:~$ docker run -it --rm --privileged --net=host --ipc=host voxl-mavsdk:v1.2
    root@m0054:/home# ./voxl2_takeoff_land.py
    Waiting for the drone to connect...
    Drone connected!
    Waiting for the drone to have a global position estimation....
    it does nothing else, these are my configurations
    "config_file_version": 1,
    "en_localhost_mavlink_udp": true,
    "localhost_udp_port_number": 14551,
    "en_vio": true,
    "vio_pipe": "qvio",
    "secondary_vio_pipe": "ov",
    "vfc_vio_pipe": "ov",
    "vio_warmup_s": 3,
    "send_odom_while_failed": true,
    "horizon_cal_tolerance": 0.5,
    "en_hitl": false,
    "offboard_mode": "trajectory",
    "follow_tag_id": 0,
    i also made my own service that communicates with the docker-mavsdk to be able to send waypoints to the mapper (extend the plan to a point) and trigger commands to the tflite server between waypoints. but it does not work mainly because I have not been able to send instructions successfully to docker-mavsdk, from qgcontrol when I give arm I get this: MAV_CMD_COMPONENT_ARM_DISARM command temporarily rejected... this has me very blocked because I need to build this solution for a precision application.
    please help!
    • Daniel RinconD Daniel Rincon
      Drone connected!
      "en_vio": true,
      "vio_pipe": "qvio",
      "vio_warmup_s": 3,
      "en_hitl": false,
      "follow_tag_id": 0,
      please help!
      @Daniel-Rincon said in Cant use Mavsdk! please Help!:
      Does your drone have GPS? Is the GPS getting a proper fix?
      Daniel RinconD 1 Reply Last reply
        Daniel Rincon
        @Eric-Katzfey Hi Erick! thanks for answering, yes my drone has GPS, we bought the Starling 2 with the most powerful construction (MRB-D0014-4-C27-M0-T0-K3), anyway, our flights will be indoor, although the tests I'm doing them from my studio, that despite being in a building, should get gps, I say this because I compare it with a Mavic 2 that if you get GPS right here, in the plotter of the portal I see activity but strangely says gps: 0, do you require to show you something specifically?
        Because this has stopped our development I was thinking about turning it around to Mavros, to see if I get a different result.
        The Workflow I have proposed is:
        voxl-mission-manager (our service) -> sends takeoff and puts the drone in hold state sends waypoints -> mapper extended to receive waypoints instead of a plan to a point -> runs mission -> in turn the manager monitors the mission and at certain waypoints activates and deactivates the tflite server -> when the mission ends it runs RTL from Mapper -> manager activates precise landing with Apriltags.
        all this we want to do autonomously, from takeoff to landing, is it possible or too ambitious?
        thanks for your answers!
          @Daniel-Rincon It seems like all that should be possible with MAVSDK. I asked about GPS because of the message MAVSDK gave you about waiting for a global position.
            Daniel Rincon
            @Eric-Katzfey Hey Eric! I finally solved the problem by setting these variables:
            RC=EXTERNAL in voxl-px4.conf
            and
            px4-param set COM_RC_IN_MODE 0
            px4-param set COM_RC_OVERRIDE 1
            px4-param set COM_ARM_WO_GPS 1
            px4-param set COM_RC_LOSS_T 30.0
            This way I was able to make the takeoff autonomous, and also to have manual control for safety.
            Now the problem I have is about the qvio, in several situations (most) ends up being very unstable, it makes erratic movements, like going much higher than the takeoff, as I see it seems something of decalibration, but how to standardize this to work well always, because the qvio so unstable is dangerous, what do you recommend me? or should I make a new thread for this question?
            thanks in advance!
              and
              thanks in advance!
              @Daniel-Rincon Yes, please start a new post for the VIO question
