  3. execute script to start docker container on start up
4 Posts 2 Posters 1.6k Views 2 Watching
  • kasarrowtecK Offline
    kasarrowtec
    i am trying to execute a script that will start a docker container every time the VOXL is started.
    A lot of the suggestions for running a script on start up on linux like using crontab or systemd or rc.local is not available with this custom yocto build on the VOXL.
    Does anyone have the best way of doing this ?
      kasarrowtec
      The most promising way seemed to be to make a service file in etc/systemd/system -
      [Unit]
      Description=Starts the mastervoxl docker container on startup.
      [Service]
      Type=simple
      ExecStart=/bin/bash /home/root/mastervoxl_init.sh
      [Install]
      WantedBy=multi-user.target
      and the script mastervoxl_init.sh being -
      #!/bin/bash
      echo 'initializing mastervoxl docker container'
      docker run -it mastervoxl /bin/bash
      • Alex KushleyevA Offline
        systemd is available on VOXL, so you could go ahead and try using the service file and script you wrote. Did you try it? However, you need to make sure that the Docker service is running, so your service file should require the Docker service also running. Docker is started by systemd as well.
          kasarrowtec
          So i managed to get it to work with the following service file and script file -
          [Unit]
          After=docker-autorun.service
          [Service]
          Type=simple
          [Install]
          #!/bin/bash
          docker run --restart=always -i mastervoxl /bin/bash
