  3. Creating image of current state
2 Posts 2 Posters 496 Views 2 Watching
  • K Offline
    K Offline
    Kessie
    Is there a way to snapshot the current state before upgrading the SDK?
    I want to try the SDK v1.4 but in case of problems need to revert back to the current state.
    Thanks in advance,
    Maarten
    • K Kessie
      Thanks in advance,
      Maarten
      @Kessie Not exactly, but the important data to retain lives in /data/ or /data/modalai
      The SDK flash will attempt to retain this partition, but in certain cases it requires a wipe.
      I would take note of /data/modalai/sku.txt
      as well as pull off any calibration files in /data/modalai, you can see if you have any onboard currently by running voxl-check-calibration
      If you have this data saved you'll have no issue getting back to your previous state, I can help guide you through it if you run into any issues.
