  3. RB5 VOXL support deprecated?
rb5
3 Posts 2 Posters 1.4k Views 1 Watching
  • S Offline
    S Offline
    smilon
    wrote on last edited by smilon
    Hello all,
    Just wondering if the VOXL support (versions upwards of 1.1.2) for RB5 has halted.
    In the light of some problems with vibration, position hold accuracy even at high GPS lock counts and voxl-open-vins-server initialization failure I am also wondering what should be the most stable SDK version for the RB5?
    Currently, that I'm facing these issues, I'm running a nightly version I don't even remember putting on there (hopefully the root of my problems):
    system-image: 1.7.1-M0052-14.1a-perf-nightly-20231025
    kernel: #1 SMP PREEMPT Thu Oct 26 05:24:02 UTC 2023 4.19.125
    hw platform: M0052
    mach.var: 1.0
    voxl-suite: 1.1.4-custom0
    Packages:
    Repo: http://voxl-packages.modalai.com/ ./dists/qrb5165/sdk-1.1/binary-arm64/
    Last Updated: 2024-09-23 14:50:45
    List:
    libmodal-cv 0.4.0
    libmodal-exposure 0.1.2
    libmodal-journal 0.2.2
    libmodal-json 0.4.3
    libmodal-pipe 2.9.2
    libqrb5165-io 0.4.2
    libvoxl-cci-direct 0.2.1
    libvoxl-cutils 0.1.1
    mv-voxl 0.1-r0
    qrb5165-bind 0.1-r0
    qrb5165-dfs-server 0.2.0
    qrb5165-imu-server 1.0.1
    qrb5165-rangefinder-server 0.1.1
    qrb5165-slpi-test-sig 01-r0
    qrb5165-system-tweaks 0.2.6
    qrb5165-tflite 2.8.0-2
    voxl-bind-spektrum 0.1.0
    voxl-camera-calibration 0.5.3
    voxl-camera-server 1.8.9+1
    voxl-ceres-solver 2:1.14.0-10
    voxl-configurator 0.5.2+1
    voxl-cpu-monitor 0.4.7
    voxl-docker-support 1.3.0
    voxl-elrs 0.1.3
    voxl-esc 1.4.0
    voxl-feature-tracker 0.3.2
    voxl-flow-server 0.3.3
    voxl-gphoto2-server 0.0.10
    voxl-jpeg-turbo 2.1.3-5
    voxl-lepton-server 1.2.0
    voxl-libgphoto2 0.0.4
    voxl-libuvc 1.0.7
    voxl-logger 0.3.5
    voxl-mavcam-manager 0.5.3
    voxl-mavlink 0.1.1
    voxl-mavlink-server 1.3.2
    voxl-microdds-agent 2.4.1-0
    voxl-modem 1.1.2
    voxl-mongoose 7.7.0-1
    voxl-mpa-to-ros 0.3.7
    voxl-mpa-to-ros2 0.0.2-202402291159
    voxl-mpa-tools 1.1.3
    voxl-neopixel-manager 0.0.3
    voxl-open-vins 0.4.4
    voxl-open-vins-server 0.2.18
    voxl-opencv 4.5.5-2
    voxl-portal 0.6.3
    voxl-px4 1.14.0-2.0.68
    voxl-px4-imu-server 0.1.2
    voxl-px4-params 0.3.3
    voxl-qvio-server 1.0.0
    voxl-remote-id 0.0.9
    voxl-ros2-foxy 0.0.1
    voxl-streamer 0.7.4
    voxl-suite 1.1.4-custom0
    voxl-tag-detector 0.0.4
    voxl-tflite-server 0.3.1
    voxl-utils 1.3.8
    voxl-uvc-server 0.1.6
    voxl-vision-hub 1.7.3
    • S smilon
      Hello all,
      hw platform: M0052
      mach.var: 1.0
      Packages:
      List:
      libmodal-cv 0.4.0
      libmodal-json 0.4.3
      libmodal-pipe 2.9.2
      libqrb5165-io 0.4.2
      mv-voxl 0.1-r0
      qrb5165-bind 0.1-r0
      voxl-elrs 0.1.3
      voxl-esc 1.4.0
      voxl-libuvc 1.0.7
      voxl-logger 0.3.5
      voxl-mavlink 0.1.1
      voxl-modem 1.1.2
      voxl-opencv 4.5.5-2
      voxl-portal 0.6.3
      voxl-streamer 0.7.4
      voxl-utils 1.3.8
      @smilon The last supported VOXL SDK for RB5 is 1.1.2.
      It does appear that you are on a custom release, I would recommend downloading the RB5 SDK 1.1.2 release from downloads.modalai.com and installing it as a sanity check.
      I believe in the 1.1.2 release a "nightly" system image was pulled in so I wouldn't worry too much about that, but if you're on the official 1.1.2 release I would expect voxl-suite to be 1.1.2
      • S Offline
        S Offline
        smilon
        Did the trick btw 🙂
