  2. VOXL Compute & Autopilot
  3. VOXL 2 IO
  4. Unable to operate motor with new VOXL2 IO board + firmware
Scheduled Pinned Locked Moved VOXL 2 IO
30 Posts 2 Posters 8.1k Views 1 Watching
  • A Aaky
    @Alex-Kushleyev Thanks for the update. Yes I have setup to build px4 firmware on my machine. Please provide me instructions to correct this problem.
    Alex KushleyevA Online
    @Aaky , please to update this value from 1000 to 1100 which will increase the minimum PWM value that is sent to the motors : https://github.com/modalai/px4-firmware/blob/voxl-dev/src/drivers/voxl2_io/voxl2_io.hpp#L137 . However, do not recalibrate the ESC with this updated value, since it will reset your ESC minimum value also to 1100. Your commanded PWM value should never get close to the absolute minimum value that the ESC starts spinning. Otherwise, your motor can stop in flight.
    So if the calibration was done at 1000us minimum signal, it is recommended to set the normal operating minimum at around 1100.
    Please try this and let me know if it solves your issue with motors not spinning up when you arm the vehicle.
    A 1 Reply Last reply
      Aaky
      @Alex-Kushleyev I have modified the firmware and also built the same. I used install-voxl.sh script to manually place the binaries in voxl2 and post that if I try to run voxl-px4 I am getting following error:
      voxl2:/$ /usr/bin/voxl-px4
      Found DSP signature file
      [INFO] Daemon mode enabled
      GPS=AUTODETECT
      RC=CRSF_RAW
      ESC=VOXL_ESC
      POWER MANAGER=VOXLPM
      DISTANCE SENSOR=NONE
      OSD=DISABLE
      DAEMON_MODE=ENABLE
      SENSOR_CAL=ACTUAL
      EXTRA STEPS:
      INFO  [muorb] SLPI: Creating pthread test_MUORB
      ERROR [muorb] SLPI: Hit maximum number of threads
      ERROR [muorb] Test timed out waiting for response
      px4: symbol lookup error: px4: undefined symbol: fc_sensor_get_time_offset
      Some undefined symbol problem. What should be further steps to debug this?
      • A Aaky
        GPS=AUTODETECT
        RC=CRSF_RAW
        ESC=VOXL_ESC
        OSD=DISABLE
        DAEMON_MODE=ENABLE
        SENSOR_CAL=ACTUAL
        EXTRA STEPS:
        Aaky
        wrote on last edited by Aaky
        #23
        @Alex-Kushleyev Got this fixed after picking debians from this link for libfc and modalslpi. Yet to test the behaviour of motors on arm.
        • A Aaky
          Aaky
          @Alex-Kushleyev I tried with updating the firmware as you mentioned to update PWM minimum value from 1000 to 1100 in voxl2_io.hpp file. With these changes I tried to arm UAV in Altitude flight mode in indoors but still motors weren't spinning and actuator_outputs topic shows all zeros for all the four motors still. Let me know further steps.
          • A Aaky
            @Aaky ,
            When you build px4, it is best to create a package (using make_package.sh) script, and install the package (.deb) instead of manually copying the files. The package installation would actually warn you that you had to update the libfc_sensor package.
            Ok, now regarding your issue.. i just realized that the pwm range is actually a param that is loaded here : https://github.com/modalai/px4-firmware/blob/voxl-dev/src/drivers/voxl2_io/voxl2_io.cpp#L23, so your change for the default value did not actually do anything (sorry about that).
            Now, let's try the following. I believe now the issue is that the mixer is set up to have the same value as DISABLED and PWM_MIN, which is an issue (i am working on providing a proper fix). However, I believe you should be able to work around it by doing the following:
            • revert VOXL2_IO_DEFAULT_MIN back to 1000 and deploy the px4 package
            • perform actuator test in QGC to find at which point (0-800) the motor starts spinning reliably. Usually, i find the point at which it just starts spinning and you can add around 40-50 to that for good margin.
            • change VOXL2_IO_MIXER_MIN from 0 to the value you found in step above (lets say 50) here : https://github.com/modalai/px4-firmware/blob/voxl-dev/src/drivers/voxl2_io/voxl2_io.hpp#L132
            • rebuild and deploy px4 package
            • use actuator test to confirm that as soon as you move the slider from disabled, the motor start spinning
            • perform flight test and make sure the motor starts spinning as soon as you arm the vehicle
            Just FYI we are working on cleaning up the voxl2_io driver, which is causing this confusion. I believe the steps above should provide a temporary workaround.
              @Aaky ,
              Aaky
              @Alex-Kushleyev Thanks Alex. This fix solved the problem and I am able to now see motors spin on arming. Thank you for your prompt and accurate response.
              • A Aaky
                @Aaky, You are welcome. I will let you know when we release an update that cleans up the voxl2_io driver and uses standard range for the mixer (1000-2000 range instead of 0-800).
                A 2 Replies Last reply
                  Aaky
                  @Alex-Kushleyev Sure Alex. Thank you!
                    Aaky
                    @Alex-Kushleyev Alex I just wanted to know with this workaround change, the minimum PWM which flight controller can provide to motors is the hardcoded value in VOXL2_IO_MIXER_MIN? So can this ensure that in flight, controller dosent provide zero values to ESC?
                    • A Aaky
                      @Aaky , the mixer should never output a value lower than mixer min (while armed).
