  3. Can I send data through the j1006 port and read it with python?
5 Posts 2 Posters 1.0k Views 1 Watching
  • José QuintanillaJ Offline
    José Quintanilla
    I currently made a code to emulate a distance sensor, and I can read the usb port of my laptop to get the data of a nodemcu and a potentiometer, I want to try this inside the drone, so I can see if using a ultrasonic sensor is viable, I don't have the necessary cable at the moment to connect the nodemcu to the J10 port that has i2c and uart communication
    this is my code
    import serial
    ser = serial.Serial('/dev/ttyUSB0')
    print(ser.name)
    while True:
     line = ser.readline()
     decoded_data = line.decode('utf-8')
     print(decoded_data)
    Does anyone know if this would work?
    • José QuintanillaJ José Quintanilla
      this is my code
      import serial
      print(ser.name)
      while True:
       print(decoded_data)
      @José-Quintanilla What hardware are you using? voxl1 / voxl2 / flight core v1 / flight core v2, etc.
      José QuintanillaJ 1 Reply Last reply
        José Quintanilla
        @tom the one included with m500 i think is the flight core v1, I'm currently using the expansion board that was included with the drone and I was able to detect the usb port, but know I need to install the serial library in the drone but I don't know how to install python libraries
          @José-Quintanilla depending on how old your M500 is, it could have a FCv1 or a FCv2.
          Are you trying to plug your hardware into the flight core (STM) side or the voxl (apq8096) side of the drone?
            José Quintanilla
            @tom I was able to pug the hardware to the expansion board that goes to the j13 port of the voxl flight,
            lsusb the one im using is the Bus 001 Device 002: ID 1a86:7523 QinHeng Electronics HL-340 USB-Serial adapter
            the success connection of the hardware
            the setup
