  3. Connecting i2c device on voxl2
61 Posts 4 Posters 39.3k Views 5 Watching
  • A Offline
    Aaky
    I am using voxl2 new SDK 1.0.0. I want to understand integration of i2c device to apps-processor. I am looking to integrate PCA9685 PWM driver IC with voxl2.
    I am aware of using J3 and J5 on VOXL2 to expose i2c bus for integration. But in my current architecture we need to use Microhard add-on board over B2B interface on voxl2, so how to enable i2c bus over Microhard add-on board? Is it possible?
    • A Aaky
      Eric KatzfeyE Online
      @Aaky Depending on what you are trying to do with the PCA9685 you could use the PX4 driver and the spare i2c port coming from the DSP on J19
      A 1 Reply Last reply
        Aaky
        wrote on last edited by Aaky
        @Eric-Katzfey Thank you for the response Eric.
        I would love to utilise I2C bus on J19 and integrate pca9685 PWM driver. I want to operate single servo motor for gripper mechanism. Is it possible with PX4 1.14? Is there PCA9685 driver on PX4 available for driving servo which can run on DSP side of PX4?
        If there is support for PCA9685 can you point me to relevant code with required configuration?
        • A Aaky
          @Aaky The code is here: https://github.com/PX4/PX4-Autopilot/tree/main/src/drivers/pca9685_pwm_out
          • A Aaky
            @Aaky I have no idea what it does or if it would work for a gripper.
              Aaky
              @Eric-Katzfey Okay. In order to run this driver on J19 free I2C bus ( Since I am using GPS + MAG on one I2C bus) what would be startup command?
              Rest I guess I can manage by compiling the driver on slpi side.
              • A Aaky
                @Aaky The extra i2c bus is bus 4. So the start command would be something like qshell pca9685_pwm_out start -b 4. Not sure about the other options.
                  Aaky
                  @Eric-Katzfey Thank you for this info. Also apology for late response.
                  On a seperate note, Can I connect I2C device to this port by using some level shifter from 1.8V to 3.3V and get any I2C device connected to apps_processor with device ID /dev/i2c-4?
                  modaltbM 1 Reply Last reply
                  • A Aaky
                    @Aaky yes this is something we've done, I have used the M0076 interposer board that has test points that I've soldered to, e.g.:
                    • modaltbM modaltb
                      Aaky
                      #10
                      @modaltb Hi, Sorry for late response. I got some time now to put my hands on VOXL2 new SDK 1.1.2 and installing it on my hardware.
                      I am integrating PCA9685 over I2C bus on J19 of VOXL2 (slpi-proc QUP3). I have made all the connection and followed your instructions to get PCA9685 driver running over my custom PX4 based on voxl-dev branch with PX4 1.14.
                      While I try to connect with PCA9685 I get following error as shown in logs.
                      voxl2:/$ /usr/bin/voxl-px4
                      Found DSP signature file
                      [INFO] Daemon mode enabled
                      GPS=AUTODETECT
                      RC=CRSF_RAW
                      ESC=VOXL_ESC
                      POWER MANAGER=VOXLPM
                      DISTANCE SENSOR=NONE
                      OSD=DISABLE
                      DAEMON_MODE=ENABLE
                      SENSOR_CAL=ACTUAL
                      EXTRA STEPS:
                      INFO  [muorb] SLPI: muorb aggregator thread running
                      INFO  [muorb] SLPI: Creating pthread test_MUORB
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097656
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097655
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097654
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_test_MUORB with tid 2097653
                      INFO  [muorb] SLPI: Advertising remote topic log_message
                      ______  __   __    ___
                      | ___ \ \ \ / /   /   |
                      | |_/ /  \ V /   / /| |
                      |  __/   /   \  / /_| |
                      | |     / /^\ \ \___  |
                      \_|     \/   \/     |_/
                      px4 starting.
                      GPS: AUTODETECT
                      RC: CRSF_RAW
                      ESC: VOXL_ESC
                      POWER MANAGER: VOXLPM
                      DISTANCE SENSOR: NONE
                      OSD: DISABLE
                      EXTRA STEPS:
                      Running on M0054
                      INFO  [muorb] SLPI: Starting param sync THREAD
                      INFO  [muorb] SLPI: before starting the qshell_entry task
                      INFO  [muorb] SLPI: Creating pthread qshell
                      INFO  [muorb] SLPI: qshell entry.....
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_qshell with tid 2097652
                      INFO  [muorb] SLPI: Init app map initialized
                      INFO  [muorb] SLPI: after starting the qshell_entry task
                      INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_reset_request) as advertised in process_remote_topic
                      INFO  [muorb] SLPI: Advertising remote topic parameter_update
                      INFO  [muorb] SLPI: Marking DeviceNode(parameter_client_set_value_request) as advertised in process_remote_to
                      INFO  [muorb] SLPI: Marking DeviceNode(parameter_server_set_used_response) as advertised in process_remote_to
                      INFO  [parameters] BSON document size 3781 bytes, decoded 3781 bytes (INT32:54, FLOAT:120)
                      INFO  [logger] logger started (mode=all)
                      INFO  [qshell] Send cmd: 'icm42688p start -s'
                      INFO  [muorb] SLPI: qshell gotten: icm42688p start -s
                      INFO  [muorb] SLPI:   arg0 = 'icm42688p'
                      INFO  [muorb] SLPI:   arg1 = 'start'
                      INFO  [muorb] SLPI:   arg2 = '-s'
                      INFO  [muorb] SLPI: *** SPI Device ID 0x26000a 2490378
                      INFO  [muorb] SLPI: ICM42688P::probe successful!
                      INFO  [muorb] SLPI: on SPI bus 1
                      INFO  [muorb] SLPI: icm42688p #0 on SPI bus 1
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI: >>> ICM42688P this: 3176cf40
                      INFO  [muorb] SLPI: Ok executing command: icm42688p start -s
                      INFO  [qshell] qshell return value timestamp: 630951289, local time: 630954493
                      INFO  [muorb] SLPI: Register interrupt b21d31a4 e61fedbc 3176cf40
                      INFO  [uORB] Advertising remote topic sensor_gyro_fifo
                      INFO  [uORB] Advertising remote topic sensor_accel_fifo
                      INFO  [uORB] Advertising remote topic imu_server
                      INFO  [qshell] Send cmd: 'icp101xx start -I -b 5'
                      INFO  [muorb] SLPI: qshell gotten: icp101xx start -I -b 5
                      INFO  [muorb] SLPI:   arg0 = 'icp101xx'
                      INFO  [muorb] SLPI:   arg2 = '-I'
                      INFO  [muorb] SLPI:   arg3 = '-b'
                      INFO  [muorb] SLPI:   arg4 = '5'
                      INFO  [muorb] SLPI: *** I2C Device ID 0xb76329 12018473
                      INFO  [muorb] SLPI: icp101xx #0 on I2C bus 5
                      INFO  [muorb] SLPI:  address 0x63
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI: Ok executing command: icp101xx start -I -b 5
                      INFO  [qshell] qshell return value timestamp: 630997270, local time: 630998910
                      INFO  [qshell] Send cmd: 'qmc5883l start -R 10 -X -b 1'
                      INFO  [muorb] SLPI: qshell gotten: qmc5883l start -R 10 -X -b 1
                      INFO  [muorb] SLPI:   arg0 = 'qmc5883l'
                      INFO  [muorb] SLPI:   arg2 = '-R'
                      INFO  [muorb] SLPI:   arg3 = '10'
                      INFO  [muorb] SLPI:   arg4 = '-X'
                      INFO  [muorb] SLPI:   arg5 = '-b'
                      INFO  [muorb] SLPI:   arg6 = '1'
                      INFO  [muorb] SLPI: *** I2C Device ID 0x80d09 527625
                      ERROR [muorb] SLPI: i2c probe failed
                      INFO  [muorb] SLPI: PX4_qshell: no instance started (no device on bus?)
                      ERROR [muorb] SLPI: Failed to execute command: qmc5883l start -R 10 -X -b 1
                      INFO  [qshell] cmd returned with: -1
                      INFO  [qshell] qshell return value timestamp: 631032869, local time: 631036064
                      ERROR [qshell] Command failed
                      INFO  [qshell] Send cmd: 'ist8310 start -R 10 -X -b 1'
                      INFO  [muorb] SLPI: qshell gotten: ist8310 start -R 10 -X -b 1
                      INFO  [muorb] SLPI:   arg0 = 'ist8310'
                      INFO  [muorb] SLPI: *** I2C Device ID 0x60e09 396809
                      INFO  [muorb] SLPI: ist8310 #0 on I2C bus 1
                      INFO  [muorb] SLPI:  (external)
                      INFO  [muorb] SLPI:  address 0xE
                      INFO  [muorb] SLPI:  rotation 10
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI: Ok executing command: ist8310 start -R 10 -X -b 1
                      INFO  [qshell] qshell return value timestamp: 631080626, local time: 631084258
                      INFO  [muorb] SLPI: qshell gotten: gps start
                      INFO  [muorb] SLPI:   arg0 = 'gps'
                      INFO  [muorb] SLPI: Creating pthread gps
                      INFO  [muorb] SLPI: Successfully created px4 task PX4_gps with tid 2097647
                      INFO  [muorb] SLPI: Ok executing command: gps start
                      INFO  [qshell] qshell return value timestamp: 631107876, local time: 631109005
                      Looking for ncp5623c RGB LED
                      INFO  [muorb] SLPI: GPS UART baudrate set to 115200
                      INFO  [qshell] Send cmd: 'rgbled_ncp5623c start -X -b 1 -f 400 -a 56'
                      INFO  [muorb] SLPI: qshell gotten: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                      INFO  [muorb] SLPI:   arg0 = 'rgbled_ncp5623c'
                      INFO  [muorb] SLPI:   arg2 = '-X'
                      INFO  [muorb] SLPI:   arg4 = '1'
                      INFO  [muorb] SLPI:   arg5 = '-f'
                      INFO  [muorb] SLPI:   arg6 = '400'
                      INFO  [muorb] SLPI:   arg7 = '-a'
                      INFO  [muorb] SLPI:   arg8 = '56'
                      INFO  [muorb] SLPI: *** I2C Device ID 0x7b3809 8075273
                      INFO  [muorb] SLPI: rgbled_ncp5623c #0 on I2C bus 1
                      INFO  [muorb] SLPI:  address 0x38
                      INFO  [muorb] SLPI:
                      INFO  [muorb] SLPI: Ok executing command: rgbled_ncp5623c start -X -b 1 -f 400 -a 56
                      INFO  [qshell] qshell return value timestamp: 631152080, local time: 631155799
                      INFO  [uORB] Advertising remote topic sensor_mag
                      INFO  [muorb] SLPI: qshell gotten: pca9685_pwm_out start -b 4 -a 0x40
                      INFO  [muorb] SLPI:   arg0 = 'pca9685_pwm_out'
                      INFO  [muorb] SLPI:   arg2 = '-b'
                      INFO  [muorb] SLPI:   arg3 = '4'
                      INFO  [muorb] SLPI:   arg4 = '-a'
                      INFO  [muorb] SLPI:   arg5 = '0x40'
                      INFO  [muorb] SLPI: Invalid bus
                      ERROR [muorb] SLPI: Task start failed (-1)
                      ERROR [muorb] SLPI: Failed to execute command: pca9685_pwm_out start -b 4 -a 0x40
                      INFO  [qshell] Send cmd: 'pca9685_pwm_out start -b 4 -a 0x40'
                      INFO  [qshell] qshell return value timestamp: 631186542, local time: 631187811
                      INFO  [uORB] Advertising remote topic sensor_baro
                      Starting VOXL ESC driver
                      INFO  [qshell] Send cmd: 'voxl_esc start'
                      INFO  [muorb] SLPI: qshell gotten: voxl_esc start
                      INFO  [muorb] SLPI:   arg0 = 'voxl_esc'
                      INFO  [uORB] Advertising remote topic actuator_outputs
                      I think PX4 is unable to identify the bus and it is saying invalid bus for command "pca9685_pwm_out start -b 4 -a 0x40". Please help.
                      • A Aaky
                        GPS=AUTODETECT
                        RC=CRSF_RAW
                        ESC=VOXL_ESC
                        OSD=DISABLE
                        DAEMON_MODE=ENABLE
                        SENSOR_CAL=ACTUAL
                        EXTRA STEPS:
                        ______  __   __    ___
                        | ___ \ \ \ / /   /   |
                        | |_/ /  \ V /   / /| |
                        |  __/   /   \  / /_| |
                        | |     / /^\ \ \___  |
                        \_|     \/   \/     |_/
                        px4 starting.
                        GPS: AUTODETECT
                        RC: CRSF_RAW
                        ESC: VOXL_ESC
                        OSD: DISABLE
                        EXTRA STEPS:
                        Running on M0054
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        INFO  [muorb] SLPI:
                        Aaky
                        • A Aaky
                          [[topic:post-is-deleted]]
                          Aaky
                          #12
                          @modaltb Got this sorted. Was some power supply problem. Now next hurdle is getting actuator output over QGC. I am unable to see PCA9685_PWM_OUT over QGC and only VOXL_ESC menu is shown. How can I enable actuator output for PCA9685 over QGC as shown on this PR? I have integrated new driver for PCA9685 from this PR into my voxl-dev fork.
                          • A Aaky
                            Aaky
                            @modaltb @Alex-Kushleyev @Eric-Katzfey
                            I am working on this integration of PCA9685 driver over I2C bus on J19 as described above.
                            I had to modify the driver code to actually make it work over slpi processor with I2C bus 4 and it gets connected well and also PCA chip seems to be communicating with VOXL. Now next I also had to include this driver on application processor post which I got to see PCA9685 control options in actuator tab on Qground control. Now I am able to select output function over any channel of PCA9685 say "Gripper" and I can actually move the slider to send PWM signals to PCA9685. I had put some debug messages in PCA9685 driver and have also checked actuator_outputs topic with px4-listener. I can see PWM data been streamed by Qground control to PCA9685 driver and also over actuator_outputs topic but still my servo dosent move at all.
                            I have changed my PCA chip multiple times just to eliminate if it's hardware problem but no luck. Can someone help me quickly to debug this problem?
                            I will also send over the modifications which I have done in build pipeline of Voxl2-px4 if necessary to see what is the problem.
                            • A Aaky
                              Aaky
                              #14
                              Update :
                              Here is the pull request which I have ported into voxl-dev branch : https://github.com/PX4/PX4-Autopilot/pull/21528
                              On main stream PX4, 'main' branch has this driver already integrated and I flashed this on Cube orange for verifying the operation. So this pca9685 driver works out of the box over there where I connected servo to pca9685 and used QGC's actuator output window to drive the servo which worked well. But with voxl2 dev branch I am unable to make it work.
                              I might be missing something in setting up I2C on slpi or setting up driver on application processor. Please help me ahead in this regards.
                              • A Aaky
                                Update :
                                @Aaky , I have not used PCA9685, but I understand what it does. Quick question, are you working integrating that due to a limitation of pwm outputs in the VOXL2_IO driver?
                                I am just asking because it is easier for us to provide support for our own hardware. I am not sure how much we can help with 3rd party hardware and drivers.
                                  Aaky
                                  @Alex-Kushleyev Yes Alex, I need one or if possible two PWM outputs for controlling one servo (Only PWM without any duty cycle requirements) and one LED from VOXL. Also Yes, I had to take up PCA9685 due to PWM output limitations in VOXL2_IO driver. Is it possible to provide more PWM channels over VOXL2_IO driver? This can solve all my problems.
                                  • A Aaky
                                    @Aaky , We are currently testing (before releasing) updated firmware for m0065 and updated voxl2_io driver that enables up to 8 actuators (configurable via standard actuator options). You could set it up as 4 motors and up to 4 additional servo / standard pwm signals. This update also fixes the actuator range from 0..800 to standard 1000-2000 range (microseconds) and i believe we have addressed potential issues in ESC calibration procedure.
                                    You can preview the current px4 branch with these changes here : https://github.com/modalai/px4-firmware/tree/voxl2-io-cleanup/src/drivers/voxl2_io but it also requires updated m0065 board firmware. If you are interested to get early access to this release, we can share it after some additional testing.
                                      Aaky
                                      @Alex-Kushleyev Thank you Alex for the update. I do have updated M0065 board and firmware, if any new compatible firmware is essential I can flash the same, just point me to right address.
                                      @Alex-Kushleyev said in Connecting i2c device on voxl2:
                                      Perfect. This will solve my problem. Actually I have very important demonstration coming up and I would need this update as soon as within next 1-2 days, Is it possible for you to share the early access of m0065 firmware and voxl2_io driver now? It would be really helpful if it dosent break anything on aircraft control side (first four PWM channels) and I can experiment with other PWM channels for controlling servo. Please let me know since this is urgent priority for me.
                                      A Alex KushleyevA 2 Replies Last reply
                                      • A Aaky
                                        Aaky
                                        #19
                                        @Alex-Kushleyev Even if this is under development but wouldn't break anything, Please share the compatible M0065 firmware with me. I will test out the voxl2_io driver from the above branch and latest m0065 firmware to operate servo maybe by today itself.
                                        Also if you are sharing the firmware now, let me know if I only cherry pick the voxl2_driver and put it into latest voxl_dev branch, would that work? Is voxl_dev in sync with voxl2_io_cleanup branch?
                                        • A Aaky
                                          #20
                                          @Aaky , We can share the pre-release m0065 firmware (and the px4 code is already in the branch i mentioned). I would recommend to begin testing without propellers on and confirm the configuration of motors and servos is working fine. We should be able to do more testing in the next 1-2 days. Also, you can revert m0065 firmware and use the px4 from voxl-dev branch.
                                          I just uploaded the test firmware here : https://gitlab.com/voxl-public/voxl-sdk/utilities/voxl2-io/-/tree/pwm-improvements/voxl2-io-tools/firmware . You can update the firmware using our voxl-esc tools:
                                          #stop px4
                                          systemctl stop voxl-px4
                                          #replace $FIRMWARE_FILE below with path to the new firmware
                                          cd /usr/share/modalai/voxl-esc-tools;
                                          ./voxl-esc-upload-firmware.py \
                                                            --id 0 \
                                                            --firmware-file $FIRMWARE_FILE \
                                                            --device /dev/slpi-uart-2
                                          Blue LED will blink slowly during firmware update.
                                          (you can also use the same procedure to restore original firmware)
                                          Then you should reboot your VOXL2 board before you use PX4 again because sometimes the firmware update causes some issues and PX4 cannot start.
                                          You can build px4 using the following branch of px4-firmware : https://github.com/modalai/px4-firmware/tree/voxl2-io-cleanup/src/drivers/voxl2_io . i suggest building the deb package and installing it using the deb, rather than copying files to target directly.
                                          When you run the new branch of PX4 for the first, time, you should run it in foreground and check if VOXL2_IO has been detected. You should get output like this :
                                          voxl-px4 -d | grep VOXL2_IO
                                          ESC: VOXL2_IO_PWM_ESC
                                          INFO  [muorb] SLPI: VOXL2_IO: Driver starting
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_BAUD  : 921600
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC1 : 101
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC2 : 102
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC3 : 103
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC4 : 104
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC5 : 0
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC6 : 0
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC7 : 0
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_FUNC8 : 0
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_DIS   : 1000
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_MIN   : 1100
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_MAX   : 2000
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_CMIN  : 1050
                                          INFO  [muorb] SLPI: VOXL2_IO: Params: VOXL2_IO_CMAX  : 2000
                                          INFO  [muorb] SLPI: VOXL2_IO: Opening UART device 2, baud rate 921600
                                          INFO  [muorb] SLPI: VOXL2_IO: Successfully opened UART device
                                          INFO  [muorb] SLPI: VOXL2_IO: Detecting M0065 board...
                                          INFO  [muorb] SLPI: VOXL2_IO: 	VOXL2_IO ID: 0
                                          INFO  [muorb] SLPI: VOXL2_IO: 	Board Type : 35: ModalAi I/O Expander (M0065)
                                          INFO  [muorb] SLPI: VOXL2_IO: 	Unique ID  : 0x4304296039364B560671FF36
                                          INFO  [muorb] SLPI: VOXL2_IO: 	Firmware   : version    2, hash f94baad1
                                          INFO  [muorb] SLPI: VOXL2_IO: 	Bootloader : version    0, hash 17147346*
                                          INFO  [muorb] SLPI: VOXL2_IO: 	Reply time : 2550us
                                          INFO  [muorb] SLPI: VOXL2_IO: Driver initialization succeeded
                                          Please note the firmware will be version 2 and hash will match the hash in the m0065 binary firmware name (f94baad1)
                                          You will see there were new parameters added, you can see their values in the print above:
                                          VOXL2_IO_DIS   : 1000 #pulse in microseconds when not armed
                                          VOXL2_IO_MIN   : 1100 #min pulse in microseconds when armed
                                          VOXL2_IO_MAX   : 2000 #max pulse in microseconds when armed
                                          VOXL2_IO_CMIN  : 1050 #min pulse in microseconds during esc calibration procedure
                                          VOXL2_IO_CMAX  : 2000 #max pulse in microseconds during esc calibration procedure
                                          You can see we added separate params for pulses to be send during ESC calibration, so that the minimum calibration pulse is lower than the minimum when armed. You should make sure your params match these, if not, then set them to these values. You should then perform the ESC calibration, I have outlined here:
                                          Suggested ESC calibration procedure:
                                          • power on VOXL2 and ESC while the PWM cable is not plugged into VOXL2. Calibration procedure only works before the ESC receives any valid signals
                                          • start px4 and QGC and verify that the calibration parameters are set to suggested values (min 1050 and max 2000) and regular min and max values are set to min=1100 and max=2000.
                                          • verify that the voxl2_io driver has started correctly : either qshell voxl2_io status or look at the blue led on M0065 should be blinking which means it is receiving the pwm commands from voxl2_io driver (the disabled commands, since not armed)
                                          • start the custom esc calibration procedure : “qshell voxl2_io calibrate_escs” and follow instructions (which are mainly just plug in the motor pwm cable into m0065 within 10 seconds). You can enter this command right in the px4 prompt, if you start px4 using voxl-px4 -d in foreground in interactive mode
                                          • after the calibration is complete, test to make sure the PWM ranges have been correctly set:
                                            • using QGC actuator test, set the actuator from disabled to 1100 and the motors should spinup and stay on (no jerking)
                                            • it is encouraged to double check the motor starting point but temporarily lowering the VOXL2_IO_MIN param to 1000 and using actuator test to find the motor starting point, should be around 1060 (the calibration value was 1050). If the motor starting point is very close to 1100, it may not be safe to use this configuration, because if mixer commands 1100 during flight, variations due to temperature of the ESC MCU could cause 1100 command to be interpreted as DISABLED.
                                            • IMPORTANT: if VOXL2_IO_MIN was temporarily modified to find the motor starting point, revert it back to the desired value of 1100
                                          In order to test actuators other than the 4 motors, you can use QGC to configure the actuator function as for normal actuators.
                                          Finally, I would like to remind you to start testing without propellers attached. We will be doing more testing in the next few days, but if you feel confident after no-prop testing, you can try flying. I have not experienced any issues with the new m0065 firmware or the voxl2_io px4 driver so far that would be a concern. However, there is still a higher than usual risk, so please test at your own risk (for now). Also please note that only v2 firmware should be used with this test branch (it actually checks for firmware version) and only v1 firmware must be used with the current px4 in voxl-dev.
                                          I hope this works for you, let me know if you run into any issues.
