  2. VOXL SDK and Software
  3. voxl-docker-mavsdk-python build problems
4 Posts 3 Posters 939 Views 2 Watching
  • Sebastian LaPointeS Offline
    Sebastian LaPointe
    Hi, I'm using voxl-docker-mavsdk-python as a base to make a docker container for the Voxl. Currently I have renamed it and added some files to the docker containers home folder. The problem is when trying to build the image on the Voxl I get a bunch of depreciation warnings when compiling MAVSDK and finally exit with out building the docker with this error
    Makefile:129: recipe for target 'all' failed
    make: *** [all] Error 2
    The command '/bin/sh -c cmake --build build/default --target install -- -j 4' returned a non-zero code: 2
    some more information is included in the two screen shots sense I can't upload a text file with the logs
      Let me take a look at this tomorrow, maybe something changed and we need to update.
        Hi @Sebastian-LaPointe , we've replicated the error and will get a solution in place and give you an update.
        • Joseph MartinsonJ Offline
          Joseph Martinson
          @Sebastian-LaPointe, I have updated the GitLab repository with changes that should fix this issue. Please let us know if the issue persists
