  3. Utilize USB-C for Bulk Storage USB Device
voxl-2-io
7 Posts 3 Posters 2.2k Views 1 Watching
  • Nathan SizemoreN Offline
    Nathan Sizemore
    I've got a VOXL2, and I need a way to enable it to act as USB Device Mode as bulk storage. Currently have been trying to setup RNDIS, but it is failing when attaching the RNDIS function.
    Is it possible to utilize the USB-C connection used for adb and configure it as a USB bulk storage device?
    This is the setup script I am working against. It is failing here:
    func=functions/rndis.usb0
    mkdir -p "${func}"
    + mkdir functions/rndis.usb0
    mkdir: cannot create directory ‘functions/rndis.usb0’: No such file or directory
      We don't know how to do this immediately, but we'll dig some and see if we can get anywhere.
      Nathan SizemoreN 1 Reply Last reply
      • Chad SweetC Chad Sweet
        Nathan Sizemore
        @Chad-Sweet Awesome, thank you!
          We have dug into this a bit more, but have not had a chance to try anything. Passing along information in case you want to dig in more
          Note: please be comfortable reflashing a bricked VOXL 2. Changing USB composition could definitely put the board into a state you cannot access it any longer
          Default USB Composition:
          901D - DIAG + ADB
          USB Composition with Mass Storage:
          902B - RNDIS + ADB + Mass Storage
          90AD - DIAG + ADB + MODEM + NMEA + QMI_RMNET + Mass Storage + DPL
          90B0 - DIAG + DUN + NMEA + RMNET + Mass Storage + DPL
          F000 - Mass Storage
          The setting is configured in /sbin/start_usb
          That script though is confusing and we're not really sure which lines are taking effect and what is the right way to set USB composition.
            Nathan Sizemore
            No worries, and yeah I've already qdl'd a few things tickering around with trying to get it to work, so comfortable with taking it from bricked to workable is a process I'm comfortable with.
            That bash script is a bit more universal based on a few things, but essentially it is ran on boot and sets up bulk + rndis on a device, and then starts up a little C program as the ffs driver. It's for NVIDIA Tegra, but should be universal as long as the kernel has the modules it needs.
            I didn't know where the usb boot startup stuff on the VOXL2 was, but I'll poke around a bit with that and see if I can get that to work.
            • Nate
              Nathan Sizemore
              @Chad-Sweet
              Following up, the USB-C connector is sending out 5v on VBUS. Is there anyway to turn this off?
              VinnyV 1 Reply Last reply
              • Nathan SizemoreN Nathan Sizemore
                @Chad-Sweet
                VinnyV Offline
                VinnyV Offline
                Vinny
                Hi @Nathan-Sizemore
                No, that is a behavior we know about, but does not impact peripheral mode (due to a diode "OR" inside the circuits).
                We are taken steps to change this behavior on future designs to allow full OTG support.
                However, Voxl2 M0054 does not have that, and can only function as device/peripheral on that port.
                When a PC/Host plugs in, the VBUS from that host is then detected by the Power Mgmt ICs (PMICs) to enable proper peripheral mode. We know that this behavior of VBUS is not ideal, but as just mentioned we will improve it later.
