px4io failed to start
I am using a Voxl 2 IO Board to get a FrSky transmiter SBUS signal but the px4io can not start when the IO board is connected to Voxl2. When running the px4io status in shell like here How to Access the PX4 Shell. I getpxh> qshell px4io status INFO [qshell] Send cmd: 'px4io status' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: px4io status ERROR [muorb] SLPI: Command px4io not found ERROR [muorb] SLPI: Failed to execute command: px4io status INFO [muorb] SLPI: Sending qshell retval with timestamp 191821788, current timestamp 191821790 INFO [qshell] cmd returned with: 1 INFO [qshell] qshell return value timestamp: 191821788, local time: 191824369 ERROR [qshell] Command failed Command 'qshell' failed, returned -1.Then I used the command without qshell but it still can't start
pxh> px4io status ERROR [px4io] not started ERROR [px4] px4_task_exit: self task not found!I attempted to command start but it appears to not have the serial port enabled
pxh> px4io start INFO [arch_px4io_serial] Open failed in init ERROR [px4io] interface init failed ERROR [px4] px4_task_exit: self task not found!The status of the Voxl IO board is Running in waiting mode
Note: I tested the same VoxI IO board in a separated Voxl2 Flight Deck and seems to be working as I get RC commands in px4-listener input_rc and the status is Running in standar mode
Am I missing something?
@andrespalomino Which port have you connected the px4io board to? The startup file /etc/modalai/voxl-px4.config shows the default way to use px4io. In there you can see that the first thing is to detect the board. What happens if you run
qshell px4io detect? -
Hi Eric,
The IO board is connected to J19 as shown here Host Connection
Then the px4io detect also shows open failed (notice below I'm running it without qshell)
pxh> qshell px4io detect INFO [qshell] Send cmd: 'px4io detect' INFO [muorb] SLPI: Marking DeviceNode(qshell_req) as advertised in process_remote_topic INFO [muorb] SLPI: qshell gotten: px4io detect ERROR [muorb] SLPI: Command px4io not found ERROR [muorb] SLPI: Failed to execute command: px4io detect INFO [muorb] SLPI: Sending qshell retval with timestamp 87951625, current timestamp 87951627 INFO [qshell] cmd returned with: 1 INFO [qshell] qshell return value timestamp: 87951625, local time: 87956506 ERROR [qshell] Command failed Command 'qshell' failed, returned -1. pxh> px4io detect ERROR [arch_px4io_serial] Open failed in init ERROR [px4io] interface init failed ERROR [px4] px4_task_exit: self task not found!Thanks
qshell px4io detect?I was looking at how px4 service is initialized voxl-px4.service and I don't have a config file
/etc/modalai/voxl-px4.config. Instead the voxl-px4 bash script points to/etc/modalai/voxl.configand that config file has the px4io detect or start under "M0052" platformThen I found the system image in this Voxl2 is
1.2.1-M0054-14.1a-perf
This is how we received it at the end of November, would this be the issue?Below the section of the voxl.config file
# On M0052 the GPS and RC drivers run on the apps processor if [ $PLATFORM = "M0052" ]; then # Pixhawk 4 GPS module gps start -d /dev/ttyHS2 # RC input may be coming via either an external M0065 (aka px4io) module # or a directly attached Spektrum receiver. First see if the M0065 is detected. # This is only applicable for M0052. M0065 is not yet supported on M0054. px4io detect PX4IO_STATUS=$? /bin/echo "PX4IO detect returned value $PX4IO_STATUS" if [ $PX4IO_STATUS -eq 0 ]; then /bin/echo "Found M0065, starting px4io" px4io start else /bin/echo "M0065 not detected, starting Spektrum RC driver" spektrum_rc start -d /dev/ttyHS1 fi # On M0054 the GPS and RC drivers run on SLPI DSP else # Pixhawk 4 GPS module # Only the newer Holybro unit is supported on M0054 qshell gps start -d 7 -b 115200 # Spektrum RC receiver qshell spektrum_rc start -d 8 fi -
# On M0052 the GPS and RC drivers run on the apps processor if [ $PLATFORM = "M0052" ]; then # Pixhawk 4 GPS module gps start -d /dev/ttyHS2 # RC input may be coming via either an external M0065 (aka px4io) module # or a directly attached Spektrum receiver. First see if the M0065 is detected. # This is only applicable for M0052. M0065 is not yet supported on M0054. px4io detect PX4IO_STATUS=$? /bin/echo "PX4IO detect returned value $PX4IO_STATUS" if [ $PX4IO_STATUS -eq 0 ]; then /bin/echo "Found M0065, starting px4io" px4io start else /bin/echo "M0065 not detected, starting Spektrum RC driver" spektrum_rc start -d /dev/ttyHS1 fi # On M0054 the GPS and RC drivers run on SLPI DSP else # Pixhawk 4 GPS module # Only the newer Holybro unit is supported on M0054 qshell gps start -d 7 -b 115200 # Spektrum RC receiver qshell spektrum_rc start -d 8 fi@andrespalomino I would definitely recommend moving to the latest platform release 0.9
@Eric-Katzfey I updated to release 0.9 and that solved the topic.
